Just call me the nitrous Noobie!!
Hello all,
Over the winter I plan on installing a ZEX system 82048 on my motor. To start I have 69' block, with SCAT 514 stroker kit with 6.8 H beam rods. Motor completely studded. Cometic head gaskets. Off the shelf roller cam, DOVE gutted heads, double valve springed alittle over recommended cam specs. Victor manifold with 1050 dom 8896-1. I have best a 10.18 with 1.39 sixty's. Just realized recently that my fuel pump was regulated at the pump @ only 6-8 psi! Now regulated at 21-23 psi, then regulated to 6-6.5 at the carb. That would explain my low mph which would be at 131-133. I have not been back to the track since the discovery, Anyway.....
Once I install this system, what kind of adjustments should I be looking to make on the carb. I know that I will have to use a y block to run a separate regulator for the nitrous. I know that I will have to retard the timing per the chart supplied if not 1 degree more than what they recommend. Should the carb have the power valve or should they be removed.
I will be using a WOT switch so the real noobie questions......Do I have to hold a stupid button all the way down the track? lol Is it best to spray entire run or if money provides use a timer? Will the DOVE heads be able to handle this? Only PLAN on using 150 shot max. I just want to hit that mid 9 sec and I would have surpass my original goal and that was build a 10 sec car right from the start.
Re: Just call me the nitrous Noobie!!
With a WOT switch once it is armed the WOT switch will trigger the solenoids. If traction is there spray the whole run. Your heads will be just fine.stang93mustang wrote:Hello all,
I know you should already know, but just in case if you run a transbrake you must run a relay to cut the nos off while on the brake with a WOT
studly- Posts : 512
studly wrote:I know you should already know, but just in case if you run a transbrake you must run a relay to cut the nos off while on the brake with a WOT
Don't have a brake but thanks for the reminder for later down the road.
» For Sale/NITROUS NOS PROGRAMMABLE NITROUS CONTROLLER #15834
» Another "noobie" from MI
» Noobie!!!!!!
» Suggest a cam to a noobie...
» noobie from australia
» Noobie!!!!!!
