question on compression ...using pump gas (a460...using fms a460 heads)
+6
4thHorseman
DaveMcLain
DanH
5pointslow
10 posters
question on compression ...using pump gas (a460...using fms a460 heads) Empty question on compression ...using pump gas (a460...using fms a460 heads)
Post  5pointslow December 6th 2010, 10:18 pm
wondering on compression ...gotta order pistons
have a460 block
fms a460 heads (2.4 intake) if matters
want to make as much power as possible obviously ...but wanna be able to go to the cruise nights around
have oliver rods ...ect .......cars fully built foxbody dm cage ect just wanna have some street fun
solid roller cam ......gotta order a cam but i know its gonna play a factor wit c/r
any info guys thanks
5pointslow
5pointslow
question on compression ...using pump gas (a460...using fms a460 heads) Empty Re: question on compression ...using pump gas (a460...using fms a460 heads)
Post  c.evans December 6th 2010, 11:27 pm
5 points,
11:1 is doable with a good tune-up and a good cooling system. You can also pull a little bit of timing out of it if need be.
Charlie
BBF VENDOR SPONSOR
BBF VENDOR SPONSOR
Post  DanH December 7th 2010, 2:47 am
street , 10 /1 then get the cam
DanH
Post  dfree383 December 7th 2010, 8:18 am
10:1 if your average or below average tuner or do not have access to consistant fuel, it will be very reliable and trouble free.
11:1-12:1 if you are an exceptional tuner and have consistant fuel, know how to set it up and drive it.
Alot will bepend on you CID and cam selection to.
Take a look at some of the dynamic compression calculators prior to purchasing a cam.
Post  DaveMcLain December 7th 2010, 2:53 pm
When it comes to compression ratio on an engine that's destined to run on cheap gas under real world conditions I tend to always lean toward the conservative side. It's MUCH better to have a lower than optimum compression ratio engine that's tuned correctly than one that has a higher than optimum ratio crutched to work.
DaveMcLain
Post  4thHorseman December 7th 2010, 5:17 pm
If you are at high altitude like me (a mile high) you can get away with running more compression also.
4thHorseman
4thHorseman
Post  BOSS 429 December 7th 2010, 9:52 pm
If this build is like any that i do for people they never stick to pump gas for long,and after a bit want more power. dont sell the engine short . Go with 11 to 1 and pull a little timing out for cruising
Post  5pointslow December 8th 2010, 6:50 pm
reason if this helps.........cars a race car basicly no heat ..no ac ..no radio ect ......... full cage .....hopping mid 9s .......was planning on something aiming for high 8s ........not looking for a long distance cruiser .....ust something to go to the cruise nights in town once in a while ....prob 10 miles at a time total ...at heart i want a race car but want to go with my old man hes got a 66 chevelle ss396 car ...
thanks and looking the 560-580 ci ball park maybe 572 ..............idk yet rods are 6.850 olivers and have 4.5 stroke crank just need pistons .......the fms a460 heads are heavly ported also ...by kaase from a while back
5pointslow
5pointslow
Post  dfree383 December 8th 2010, 6:53 pm
if its only for 10 mile runs and alot of track time.... why not just put the squeeze to it and run some race gas?
Post  5pointslow December 8th 2010, 10:05 pm
what run .......... pump gas and race gas with nitrous
5pointslow
5pointslow
Post  dfree383 December 9th 2010, 8:44 am
get the compression up and run race gas if your only going to use it once in awhile and for short trips.
Post  5pointslow December 10th 2010, 6:26 pm
if i did 11.1 compression with my a460 fms heads that are ported with an sv1 .......around 560-580 ci ............what kind of power should this thing make ballpark
...i know it will make steam if it was 14.1 i see those combos ............want a pump gas car thats is capable of mid 9s or low 9s .............cars a gutted 90lx notchback ......full cm cage mioni tubbed ect ...........should weight 2800lbs with bb
theres obviosly a lot of variables cam , intake ect ..........lets just say i had the right matched parts with this compression and my heads
5pointslow
5pointslow
Post  BIGDOG466 December 10th 2010, 6:30 pm
use E-85 Very Happy Very Happy
BIGDOG466
BIGDOG466
Post  5pointslow December 12th 2010, 10:44 am
prob just go 11.1 compression wish it well with a good tune run 93 with some good octane booster ..............
any idea power and times this could be in a 2800lb car ? a lot of variables
5pointslow
5pointslow
Post  Filucky December 12th 2010, 12:09 pm
I ran a 557 in my old jetboat with ported A460's and a TF TR with 1050's, a .713 lift cam and 10.2:1 cr, it turned a A cut impeller 6200 and on the impeller/hp chart that showd to be about 800-825hp. Motor could be driven all day long on any pumpgas and pulled like a freight train! This was also in the Texas summer, 100+ degrees and 80+ hummidity. Cool
Filucky
Filucky
Post  5pointslow December 12th 2010, 9:13 pm
should i have prob runnin mid 9s with a combo like this ......cam prob can be real aggressive due to very little street driving just backroads when used
just gonna run 11.1 using pump fuel ..............
5pointslow
5pointslow
Post  bigblok2000ranger December 13th 2010, 12:12 am
I am running 10.9:1 on 93 octane, I would say listen to Charlie. Give Lem Evans a call and get a gameplan together for pistons and cam, run compression close to 11:1 then you can have your cake and eat it too. So far I have gone 10.64@126 with my truck and that was spinning and also got a good 800 pounds on your car. I am running TFS street heads so I would think mid 9's with what you have.
bigblok2000ranger
bigblok2000ranger
