Mallory Unilite dizzy, Moroso wires
the dizzy,Mechanical advance plus Blue Max Moroso wires, bronze gear and the spike supressor from Mallory ( spike suppresor saves the optic sensor in the unilite )
ready to drop in and run
Lists for $275 @ Summit for the dizzy alone.
$120.00 plus shipping.
JS
317 503 0770
JS
317 503 0770
Re: Mallory Unilite dizzy, Moroso wires
Thats dirt cheap. I have one for a backup and I sure would'nt take that for it.
At the risk of sounding stupid what changes or additions do you have to make to run this with a msd box ie a 6al box ????
The one I have was on my car when I got it. I ran it w/7al2 box. The only reason I took mine out was I went w/crank trigger setup.I actually liked the module dizzy better than the ct.
Jerry after I finish ordering my parts this week if I have enough left over I will buy it this weekend for mine and put my duro spark up for a back up.
dr's wife racing wrote:At the risk of sounding stupid what changes or additions do you have to make to run this with a msd box ie a 6al box ????
plug it up to where your duraspark plugs into now for the pickup.
works the same as a duraspark. its an optic sensor not a magnet. Also it has bearings stead of bushings..... People quit running Unilites cause it cost 60 bucks to replace the optic sensor and if you plugged a hot battery charger to the car, some times it would get the optic sensor.... UNLESS you run the little filter you see in the picture. takes care of spikes.
ran it flawless with a 6AL and later 7AL for yrs zero problems.
I don't want to run in front of anyone.I will take the dist. if 69F-100 pass's on it. Thanks Ward
Ward you was 1st you was asking about it before me you have 1st choice if you didn't want it I would get it.
Good dizzy. if I was not going EFI I would keep mine. heck of a deal good luck. did you ever run the black type ballast resistor with yours?
bbfhnj- Posts : 13
I don't need it I have a msd for my primay will use it for a back up. I put my back up in my sons windsor.If you need it buy it,it won't bother me at all. I just don't like to feel like I'm running in front of somebody. He probaly wants his money or he wouldn't have it for sale.If you I wind up buying shipping will be to 35555 fayette al. What type of payment do you prefer? thanks Ward
ward if you don'tt need it I would like to get it for mine
Jim
Jim
Consider it yours, I was going to use it as a backup. Thanks, Ward
Jerry I will get with you tonight
Jim
Jim
MONEY ORDER IS HEADING YOUR WAY
» Mallory Distributor
» Moroso wires
» moroso 73809 plug wires
» Mallory Distributor & Regulator
» 140 MALLORY PUMP
» Moroso wires
» 140 MALLORY PUMP
