Plastigage
bb429power
bigblok2000ranger
nuclearcobra
Plastigage
How many of you use plastigage to check clearances and is one brand better than the other ?
nuclearcobra- BBF CONTRIBUTOR
Re: Plastigage
Last ditch emergency measure only, get the proper tools or borrow them and do it right. Set of mics and a dial bore gauge are a must if your going to build engines.
Re: Plastigage
Never liked the stuff! Too much room for error.
Re: Plastigage
I like the bore gauge's, make it fast and I know I'm getting a good reafing. And I AM speaking from personal experience, not from something I was told or read. I have used both.
bb429power- Posts : 3129
Re: Plastigage
Lem Evans wrote:Better than nothing...that's the deal. A mechanical method is much better.
X2, You will be in the ball park w/it. I assembled alot of engines w/it only back in the day. I know some racers that don't use anything at all,because they say they leave it up to their machinist. I trust my machinist too,but not that much.
Re: Plastigage
bbf-falcon wrote:Lem Evans wrote:Better than nothing...that's the deal. A mechanical method is much better.
We have a popular phrase at work... "Trust, but verify"..
IMO, we have to, putting fighter aircraft in the air every day..
Re: Plastigage
Well thanks for the replys guys its the same thing Melvyn (514fox87) told me he dont care for it either. Looks like i need to order some tools thismorning then or borrow them from Mel again but i should have my own set anyway, any ideas on what brand to get or are they all decent ?
Re: Plastigage
For as often as you will probably use them a set of cheap mics off ebay or something similar will be fine, especially since you are basically using them for comparison purposes. A bore gauge from Central or some thing similar would be fine. Preferably something that will get into the tenths of thousandths.
