wishbone or panhard bar
i have the panhard bar on my ladder bar deal ... would the wishbone be a better way to go ? what is the diff ?
Re: wishbone or panhard bar
no need for a wishbone on a ladder bar deal.
maybe i should have diagonal bar instead of panhard (because thats not what it is called)
i just notice a slight amount of play in the rear ..only in one direction with the diagonal bar ...so what about an x bar set up like these
http://www.cachassisworks.com/c-86-track-locaters-x-style.aspx
here is the wishbone deal
http://www.cachassisworks.com/c-89-wishbone-locaters.aspx
I have just the diagonal bar and she is solid, we did ditch the one that came with the kit and make a bigger diameter one though. Also the tabs are welded to the front of the ds bar and the rear of the ps bar, good fitting bolts..................all equal no slop.
A diagonal link that's brackets are bolted to the chassis/housing brackets is going to feel "looser" than a diagonal link with brackets welded directly to the front/rear of the ladder bars. This is because the "bolt-on" diagonal link by design has to be a longer bar (more material to flex) & it sits installed at a steeper angle (between the ladder bars) offering less side loading ability.bruno wrote:........i just notice a slight amount of play in the rear ......
A weld-on diagonal link design uses a shorter bar length (less material to flex) & installs at an angle (between the ladder bars) that is much closer to the "ideal" side loading angle of 45*.
DILLIGASDAVE- Posts : 2262
richter69 wrote:no need for a wishbone on a ladder bar deal.
I like the wishbone and ladder bar combo myself. We could tell a BIG difference on Larry's little ChevyII with the stick shift especially on the slow down after a pass. Car did not wander or walk around while on the brakes after the wishbone install. JMO
Travis
TravisRice- BBF CONTRIBUTOR
I should have stated no need for one if the diagonal link is done right lol.
richter69 wrote:I should have stated no need for one if the diagonal link is done right lol.
Yeah, we probably f-ed up that diagonal link. If the ladder bars are 32" long ,big tire and only 22-24" apart, it is a lot harder to make a diagonal link work properly compared to a small tire wide spread say 30 -32" separation width. The angle changes dramatically between the Two no matter if you are bolted through the hiems front and back or welded tabs on the bars theirselves. I personally don't care for the welded tabs on the bars for the simple fact you are side loading the tubing ( on the ladder bars ) and have the possibility of bending the ladder bars more so then bolting through the hiems . Again JMO not that it really matters, ( LOL )
I am using a bolt in diagonal link on my car , the only thing I do not like about it is if I move the bottom 4 link bars I have to re - center the rear end , on the other hand the bottom bars are seldom moved unless you make a big power adjustment so its not that big of an issue.
KY JELLY- Posts : 1530
In comparison it should be mentioned that a diagonal link's mounts/pivot points must fall on the same plane (when viewed from the side) as the ladder bar's (and also 4-link's bottom bar's) pivot points. A wishbone doesn't need to fall on the same plane because of it's slip-joint. And with an X-link it depends on the design used. With a slip-joint X-link it's not necessary, and with a non slip-joint X-link it must be on the same plane.
A wishbone can at times also have some problems dealing with side loading on ladder bars that are mounted real close together. The long length combined with a narrow width really loads the wishbone's slip-joint on one end & the two rod-ends/brackets on the other. So in this situation using bigger tubing & rod-ends for the wishbone is a good idea.
But in my opinion the best choice for really narrow mounted ladder bars is one of the X-link designs mentioned.
Witch one is best if the car is mostly street driven.
ive heard ether or, but not both, but also have heard of a few street and track cars running both with no problems
looks like they would bind.
OH! with ladder bars.
res0rli9- BBF CONTRIBUTOR
If by "best" for ladder bars on the street you mean "strongest" (for dealing with corner turning/side loading street use) then the only real choices are a panhard bar, or a Watts link.res0rli9 wrote:Witch one is best if the car is mostly street driven.
A panhard bar is the least complex & strongest for dealing with side loading, but they do pull the housing to the side a small amount during suspension travel. How much a panhard bar pulls the housing to one side depends on total suspension travel distance, it's installed length (shorter bar pulls more, longer bar pulls less) & how equal both it's pivot point heights are off the ground at car ride height.
A Watts link doesn't/shouldn't pull the housing to the side (if correctly designed/installed) like a panhard bar can. But a Watts link is much more complicated & takes up much more room under the car.
You never use multiple/different housing centering methods/designs on any given car. You pick one method & only one.
A few door cars around here have started using an X welded into the bottom 4 link bars in place of a wisbone or diagonal link. They also figured out that this replaced the need for an anti-roll bar as well. It seems to work pretty good. The 4-link rails have been doing this for a while and these guys adapted it to their door cars.
BigDave65- Posts : 567
On dragsters they call that a "swing-arm" setup (for some damn reason) even though it's just like you say really just the bottom bars of their 4-link welded together with an "X". Using the name "swing-arm" for the welded 4-link bars makes no sense to me cuz a true swing-arm design "swings/rotates" from a single front pivot point (each side) like some Pro Mods used to have & also like what motorcycles use.BigDave65 wrote:A few door cars around here have started using an X welded into the bottom 4 link bars in place of a wisbone or diagonal link. They also figured out that this replaced the need for an anti-roll bar as well. It seems to work pretty good. The 4-link rails have been doing this for a while and these guys adapted it to their door cars.
Supposedly Murray Anderson has also tried the welded 4-link bottom bar layout as his next evolutionary design step to take the place of his older traditional P/M swing-arm design since the "true" older swing-arm design does lack any real amount of adjustment.
