Main stud torque
Main stud torque Empty Main stud torque
Post  jbozzelle December 29th 2010, 12:06 pm
what should the main studs be torqued to? Also, the block and caps show some fretting. Someone suggested I wipe some antisieze between them and torque them a little more. Sound ok?
Main stud torque Empty Re: Main stud torque
Post  BOSS 429 December 29th 2010, 7:36 pm
jbozzelle wrote:what should the main studs be torqued to? Also, the block and caps show some fretting. Someone suggested I wipe some antisieze between them and torque them a little more. Sound ok?
i have to ask are you torquing them down as installing them in the block? or do you mean finish torque crank installed?
studs should be hand tight bottomed in block. i just want to make sure we were on same page.
as far as antisieze question..............NO!
Post  Lem Evans December 29th 2010, 8:52 pm
1] like boss 429 said.....antisieze between the cap and block is a joke.
2] have you ran these studs before?......if so what lube and tq. was used?
Post  jbozzelle December 29th 2010, 9:06 pm
They are used. I got them from Ladowski so I don't know what he torqued them to or with. I'll have to call and ask.
How will what was used before as lube affect them this time?
Post  Lem Evans December 29th 2010, 9:28 pm
You got the block and the studs from Kyle?
Post  jbozzelle December 29th 2010, 9:57 pm
Not Kyle, but Cody. I got the entire shortblock from him. I do recall seeing some ARP lube on the studs when I disassembled it. The shortblock was ran in it's current form. We disassembled it at the Bash for inspection. I'm currently cleaning and reassembling it.
Post  Lem Evans December 29th 2010, 10:33 pm
My best quess is 115-120 with 30-40 wt. oil and make sure the housing bore is in spec.
Post  jbozzelle December 29th 2010, 11:00 pm
