460 8.5 6500 rpm cam
460 8.5  6500 rpm cam Empty 460 8.5 6500 rpm cam
Post  375ultra December 30th 2010, 6:22 pm
Would it be possable to grind a camshaft for a 8.5-1 460 to work with a 4500 rpm stall torque converter and make power to 6500 rpm? Right now I have a summit 3501, max ported c9ve heads 2.25 int 1.74 exh 83 cc chambers victor jr intake, 2" fms headers and nitrous 125-300 kit. This is an 86 mustang 3850 lbs w/driver 460, c/6, art car 4500 stall, 3.73 8.8. It has run a best of 12.5 @108 mph, 1/4 mile 1.82 60', at 3000' elevation w/o the nitrous. I was going to turbocharge but changed my mind.
375ultra
460 8.5  6500 rpm cam Empty Re: 460 8.5 6500 rpm cam
Post  375ultra December 30th 2010, 9:43 pm
If I cant turn 6500 with 8.5-1 and power, how much can I mill the c9ve heads, and how much compression increase can I expect?
375ultra
Post  95lightiningguy December 30th 2010, 11:06 pm
Have these heads had the chambers measured? The c9 heads had 75cc +/- chambers. Need more info on the combination.
95lightiningguy
95lightiningguy
Post  375ultra December 30th 2010, 11:19 pm
the heads were ground out to the gasket to lower the compression ratio and cc,d at 83
375ultra
Post  rmcomprandy December 31st 2010, 12:03 pm
375ultra wrote: the heads were ground out to the gasket to lower the compression ratio and cc,d at 83
Well, I guess you better get a good block to get the BORE size out to the gasket also. The head should be ground-out to the bore, NOT the gasket.
To answer your question, yes a custom cam can be made to make power to 6500 RPM but, won't make up for the lack of compression.
Post  BOSS 429 December 31st 2010, 1:59 pm
why was comp lowered so much?
Post  375ultra December 31st 2010, 3:37 pm
When the engine was built it was going to be turbocharged. But since that time I decided that I didnt want that much power in this car. The city tore out the dragstrip and now its 110 miles to las vegas the closest track. This is mostly a street car and I want to have the sound of nasty more than stealth. I bought this car new and its only been licensed 4 times in 24 years (22000 miles).
375ultra
