IF YOU OWN A FOX BODY WITH ROLL CAGE CLICK HERE!
'65 T-BOLT
Larry Williams
JT557
IF YOU OWN A FOX BODY WITH ROLL CAGE CLICK HERE! Empty IF YOU OWN A FOX BODY WITH ROLL CAGE CLICK HERE!
Post  JT557 December 31st 2010, 10:10 am
I'VE GOT A 88 STANG NEED TO KNOW IF YOU THINK I NEED THE MOTOR MOUNTS ON MY CHASIS OR DO I CUT THEM OUT AND JUST USE THE MOTOR PLATE OR LEAVE THEM,AND FIGHT THE HEADERS WHEN THEY GET INSTALLED, ALSO DOES THE FRONT SWAY BAR COME OUT FOR THE MOTOR PLATE TO BE MOUNTED ????(I HAVE THE 460 SWAP MOUNT'S AND STOCK K MEMBER)WHAT'S YOUR TAKE?????
JT557
JT557
IF YOU OWN A FOX BODY WITH ROLL CAGE CLICK HERE! Empty Re: IF YOU OWN A FOX BODY WITH ROLL CAGE CLICK HERE!
Post  Larry Williams December 31st 2010, 10:20 am
I took the mounts out and just use the plate.
Larry Williams
Larry Williams
Post  '65 T-BOLT December 31st 2010, 10:40 am
front and mid plate
'65 T-BOLT
'65 T-BOLT
Post  JT557 December 31st 2010, 11:07 am
Larry Williams wrote:I took the mounts out and just use the plate.
so you got a fox body also ??
JT557
JT557
Post  richter69 December 31st 2010, 12:06 pm
IF YOU OWN A FOX BODY WITH ROLL CAGE CLICK HERE! TV10-17-09003-4
IF YOU OWN A FOX BODY WITH ROLL CAGE CLICK HERE! TV10-17-09002-8-1
front and mid plate..................no tranny mount............. Wink
Post  Larry Williams December 31st 2010, 12:33 pm
yes a 1988 notch with a small block 393
Larry Williams
Larry Williams
IF YOU OWN A FOX BODY WITH ROLL CAGE CLICK HERE! Empty comm
Post  JT557 December 31st 2010, 1:16 pm
are you using the trans cross member???
JT557
JT557
Post  DFI429 December 31st 2010, 1:39 pm
richter69 wrote:front and mid plate..................no tranny mount............. Wink
Jon, what say you about that for a BBF/C6 in a Fox?
DFI429
DFI429
Post  BOSS 429 December 31st 2010, 2:15 pm
Plate. For back half cars i only use a plate in the front,makes life very easy for headers,and less starter problems ect. full chassie id use both
Post  BOSS 429 December 31st 2010, 2:19 pm
JT557 wrote:I'VE GOT A 88 STANG NEED TO KNOW IF YOU THINK I NEED THE MOTOR MOUNTS ON MY CHASIS OR DO I CUT THEM OUT AND JUST USE THE MOTOR PLATE OR LEAVE THEM,AND FIGHT THE HEADERS WHEN THEY GET INSTALLED, ALSO DOES THE FRONT SWAY BAR COME OUT FOR THE MOTOR PLATE TO BE MOUNTED ????(I HAVE THE 460 SWAP MOUNT'S AND STOCK K MEMBER)WHAT'S YOUR TAKE?????
sway bar can stay if you want it to,but most of the time we leave them out
Post  richter69 December 31st 2010, 4:29 pm
The front/mid plate is a winner in any combo..............but the midplate needs to be designed and installed in a proper manner.
C6 with fron- mid plates and no tranny crossmember is fine, but again it needs a well designed and installed plate.
Post  1BADBIRD January 7th 2011, 5:40 pm
My Tbird is a fox body and I have a front plate and a crossmember under my c-6 with no midplate .
Bird runs 11.5's pulling the wheels all day !
[img]IF YOU OWN A FOX BODY WITH ROLL CAGE CLICK HERE! Tbirdmotor[/img]
1BADBIRD
1BADBIRD
Post  DILLIGASDAVE January 7th 2011, 8:52 pm
If your going to invest the time & effort of installing a front plate, you might as well finish the job 100% & install a mid plate too while your at it. Wink
