Roller Spring Perches for a Mustang?
+6
Greg_P
bosshoss
jcoxracing
10 posters
Roller Spring Perches for a Mustang? Empty Roller Spring Perches for a Mustang?
Post  jcoxracing December 31st 2010, 10:42 pm
Are roller spring perches that much better than new/stock perches? I am curious if it is worth $300 on my drag only 3300 lbs stock suspension 67 mustang that runs 9.90's. It launches the front wheels a couple feet off the ground and seems to drive fine with the stock perches.
Thanks for the help
Justin
jcoxracing
jcoxracing
Roller Spring Perches for a Mustang? Empty Re: Roller Spring Perches for a Mustang?
Post  bosshoss January 1st 2011, 2:23 am
Roller spring perches for leaf spring cars are only required on ladder bar cars where the front mount of the ladder bar is not the same as the front mount of the leaf spring. In fact using them on a car that does not have something to stop the rearend from rotating would be rather disasterous.
dkp
bosshoss
bosshoss
Post  richter69 January 1st 2011, 11:38 am
I think he is talking about the perches for the front suspension of his car, I had some back i the day and it really freed up the front end..................saw no gain what so ever. IMO if the car is working awesome now I would save the money.
Post  jcoxracing January 2nd 2011, 1:19 am
Yeah I was referring to the front spring perches, I guess I'll spend my money else where. Thanks for the replies
Justin
jcoxracing
jcoxracing
Post  res0rli9 January 2nd 2011, 4:28 am
Greg P put them in his car and it made a big diff.
Post  richter69 January 2nd 2011, 11:33 am
Greg made his, I'm not saying they are a waste of time or money, I just dont think you'll see a 300 dollar difference considering the car works good as it is lol.
Post  bosshoss January 2nd 2011, 2:45 pm
I guess if the old ones where really badly seized and the new ones allowed the front end to rise easier you could see better weight transfer. Like Jon said tho. If it aint broke dont fix it. Maybe more, quicker weight transfer would upset the apple cart and cause some other problem that would slow the car down. Every car is different they say.
dkp
bosshoss
bosshoss
Post  DILLIGASDAVE January 2nd 2011, 9:34 pm
richter69 wrote:......IMO if the car is working awesome now I would save the money.
That is a good point.
There are times where you see a guy with an already "working" car decide to make a ladder bar/4-link change wanting to make the car launch harder/more violent (for whatever reason)......only to end up calming it back down at the track with a tighter shock setting. Or the guy that frees up the front suspension on a car that already works good only to find out he now needs limiters on the front to calm it back down.
It all depends on the total combo.
Post  Greg_P January 3rd 2011, 1:20 pm
I did make my spring perches. Very easy to do and inexpensive. It also made a very big difference in the free movement of the front suspension.
I can't see where the extreme friction of the stock spring perch would ever be a good thing.
Greg
Greg_P
Greg_P
Post  4thHorseman January 6th 2011, 7:37 pm
My stockers were so bound up when I put them in a vise I had to hit 'em with a hammer to get them to move. Rollers really helped me. If your stockers are in good shape your gain may be minumal.
4thHorseman
4thHorseman
Post  YellowStangDuane January 6th 2011, 11:13 pm
Greg, post some details on conversion... And can you do it to old ones that are bad?
YellowStangDuane
YellowStangDuane
Roller Spring Perches for a Mustang? Empty They are around $180, not $300
Post  nickbay January 9th 2011, 1:31 pm
One thing that was not mentioned was that the roller spring perch will always have the same resistance, where as a stock set will eventually loosen up, or worse yet bind, possibly creating frontend lift inconsistencys. On a drag only car I would think stock style would last a long time though. I run them and it did free up the frontend. There is more to be gained by using bearings in the control arms, especially the lower control arm with the rubber bushing. Also the original strut rod bushings bind up the frontend, and bearing type replacements free it up some.
Link to where you can get them:
http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=270682253301&crlp=1_263602_304652&ff4=263602_304652&viewitem=&guid=e74ad57f1290a0e66926b916ffe64f68&hlp=false&rvr_id=195849553015&ua=WVI7&itemid=270682253301
nickbay
nickbay
Post  Greg_P January 10th 2011, 6:50 pm
Here's where I got the basic idea. I kinda copied this design and it turned out great.
http://home.bresnan.net/%7Edazed/opentracker
Greg_P
Greg_P
Post  72mav January 10th 2011, 8:48 pm
Check out www.brownshoeproductions.com
He sells kits and is a member here.
72mav
72mav
