Single Stage External WET SUMP OIL PUMP AND VACUM PUMP
studly
Single Stage External WET SUMP OIL PUMP AND VACUM PUMP Empty Single Stage External WET SUMP OIL PUMP AND VACUM PUMP
Post  studly January 2nd 2011, 7:24 pm
First time using an External Wet sump pump and Vacuum pump. any suggestions on pressure for oil and how much vac cum should you be pulling. this will be a NOS motor with heavy spray.
86OO RPMs
Oliver Billet rods with ARP 625 Bolts
Diamond Pistons with .043 backcut top ring
.043 napier second ring
20 pound oil ring standard
any thoughts?
studly
studly
Single Stage External WET SUMP OIL PUMP AND VACUM PUMP Empty Re: Single Stage External WET SUMP OIL PUMP AND VACUM PUMP
Post  BOSS 429 January 2nd 2011, 7:31 pm
studly wrote:First time using an External Wet sump pump and Vacuum pump. any suggestions on pressure for oil and how much vac cum should you be pulling. this will be a NOS motor with heavy spray.
86OO RPMs
any thoughts?
PETERSON makes a good one . is the block alum? it makes a differance
Post  studly January 2nd 2011, 7:43 pm
This is a Dart Iron Eagle SBF 423 Cubic inches
Moroso single stage external pump
Moroso 4vane enhanced designed vacuum pump
Moroso Drive Mandrel
Asked over here just did not want a bunch of BS from the Bullet thanks for the replies
studly
studly
Post  whatbumper January 3rd 2011, 12:49 am
I would run about 12" of vacuum but oil pressure is up to you. we have ours set about 65lbs.
Post  Bret Powell January 4th 2011, 10:57 pm
whatbumper wrote:I would run about 12" of vacuum but oil pressure is up to you. we have ours set about 65lbs.
Why just 12# if he's using an external pump?
Bret
Bret Powell
Post  DanH January 5th 2011, 6:49 am
Bret
External acts the same as the internal . pump is pulling against vacuum
DanH
Post  richter69 January 5th 2011, 12:30 pm
good thing with the external pump is you can reach over and turn the oil press up if you need to.
Post  whatbumper January 5th 2011, 5:57 pm
Bret
richter69 wrote:good thing with the external pump is you can reach over and turn the oil press up if you need to.
YEP and YEP.
Single Stage External WET SUMP OIL PUMP AND VACUM PUMP Empty Morosso vacuum pump with internal oil pump??
Post  GaryS January 20th 2011, 5:45 pm
I am considering a Morosso vacuum pump to replace the PCV system. With the extra crankcase pressure of a 557, I don't want oil blowing out the holes or making new holes by blowing gaskets. I searched the forum, but very little discussion about this subject. Is the Morosso pump way overkill and an old OEM emissions pump do the job? Has anyone got a plan?
GaryS
GaryS
Post  whatbumper January 21st 2011, 9:47 am
GaryS wrote:I am considering a Morosso vacuum pump to replace the PCV system. With the extra crankcase pressure of a 557, I don't want oil blowing out the holes or making new holes by blowing gaskets. I searched the forum, but very little discussion about this subject. Is the Morosso pump way overkill and an old OEM emissions pump do the job? Has anyone got a plan?
I would use a race vacuum pump before the emissions stuff. You do need a larger pump for larger motors because not only do you have more volume above the pistons in bigger motors you do in the bottom too so the crankcase is essentially bigger. Have you checked out these? http://www.gzmotorsports.com/vacuum-pumps.html
