wanted-- 390 pistons
wanted-- 390 pistons Empty wanted-- 390 pistons
Post  johndickjr January 10th 2011, 10:27 am
looking for a set of 390 pistons...need to be standard bore
johndickjr
wanted-- 390 pistons Empty Re: wanted-- 390 pistons
Post  dfree383 January 10th 2011, 1:13 pm
I'll sell you a complete 428 Short Block...... Laughing
Post  bbf-falcon January 10th 2011, 2:20 pm
4 barrel or 2 barrel pistons?got a couple sets. call Randy at 740-682-3211
Post  johndickjr January 10th 2011, 2:28 pm
bbf-falcon wrote:4 barrel or 2 barrel pistons?got a couple sets. call Randy at 740-682-3211
prefer some that are either flat tops or dome im.not sure what the difference is a 2 or barrel 4 piston on the FE motors
johndickjr
Post  johndickjr January 10th 2011, 6:30 pm
i called but got a answering machine..will try again later
johndickjr
Post  bbf-falcon January 10th 2011, 7:43 pm
It has alot to do w/year of pistons. My experience w/390 pistons is the 4 barrel flat w/ 4 eyebrows and the 2 barrel have a dish. Some are different.
Post  johndickjr January 10th 2011, 10:23 pm
bbf-falcon wrote:It has alot to do w/year of pistons. My experience w/390 pistons is the 4 barrel flat w/ 4 eyebrows and the 2 barrel have a dish. Some are different.
no go..really needing some forged piston..but thanks for the help
johndickjr
Post  dfree383 January 11th 2011, 8:09 am
428.... Forged Speed pros...... .030 Over, Internaly balanced and Ready to go...... Laughing
Post  johndickjr January 11th 2011, 9:45 am
dfree383 wrote:428.... Forged Speed pros...... .030 Over, Internaly balanced and Ready to go...... Laughing
these piston are going in my 300 straight six
johndickjr
Post  dfree383 January 11th 2011, 9:49 am
OK.... Laughing Laughing
Post  DanH January 13th 2011, 5:08 am
360 truck pistons , same as 390 but with a heavy wrist pin
DanH
Post  johndickjr January 13th 2011, 10:16 am
DanH wrote:360 truck pistons , same as 390 but with a heavy wrist pin
if they are forged and standard bore im interested
johndickjr
Post  DanH January 13th 2011, 5:59 pm
I don't have a set, just telling what else fits
DanH
Post  johndickjr January 13th 2011, 6:34 pm
oic..yep i knew that, also the 331 ford stroker small block pistons will work if you use the 300 ford 3.98 stroke crank(stock stroke) and the 6.8 long 240 rod and use the early rods that have the .912 pin, also you can use chevy 383 pistons for a 6 inch rod but have to have the pin opened to .927, there is several ways to do it, pros and cons of each way,
johndickjr
Post  DanH January 14th 2011, 4:24 am
I do have 6 new 1.200 ch pistons 4.035 over ,use with 24o rods , also got a steel crank . forgot pistons are FT
DanH
Post  johndickjr January 14th 2011, 10:55 am
DanH wrote:I do have 6 new 1.200 ch pistons 4.035 over ,use with 24o rods , also got a steel crank . forgot pistons are FT
i have a steel crank..but pm sent of the pistons
johndickjr
Post  bbf-falcon January 14th 2011, 2:42 pm
Sorry,original post didn't mention forged Smile
