Conventional or Not
Conventional or Not
Would the New Kaase boss 429 big block ford head be Conventional or Non Conventional? Thanks
1FastZ28- Posts : 3
Re: Conventional or Not
WTF is Conventional.................. Your hanging around to many Chevy Bozo's......
Based on the Chevy "Bozos", it would be considered a conventional head.
Curt- Posts : 2791
Curt wrote:Based on the Chevy "Bozos", it would be considered a conventional head.
Your right the Chevy guys are allowed to move the valves and raise the ports too.... Thats Conventional "Race Heads"....
I can see the headlines now.... "Factory Boss heads Banned because the Chevy "Conventional Race Heads" can't run with them"....... Same crap they do when some hillbilly shows up with a set of Cleveland heads in the circle track stuff and hands them their asses.......
Chevy guys are a bunch of crybabies...... Rather than figure out how to get their junk to run.... they outlaw the competition to only allow their stuff to run.... BO F'n HOOOOO...
and I love the 1fastZ28 screen name....... Trying to say something their big boy???
Just a simple fuckin question. Thanks for all the input!
1FastZ28- Posts : 3
1FastZ28 wrote:Just a simple fuckin question. Thanks for all the input!
Simple Fucking answer.... They are "FACTORY"......... Fords don't use the term "CONVENTIONAL"...... Thats a GM term to limit the competition.....
dfree383 wrote:Simple Fucking answer....
LOL
To the OP.. It may seem like a harsh welcoming... but hang around long enough and you'll learn this is the coolest camp on the planet
Unless you're just trolling..
Yes, they are a "convential" head. They are reproductions of the original factory Boss 429 heads. They use a factory intake gasket in the correct "low" port location and they use a factory exhaust gasket, also in the correct "low" port location. Some improvements were made in the valve train rocker geometry and also in the oiling.
Furthermore they are more "stock" than most all aftermarket "convential" Chevy heads that have had the intake valve incline angle changed from the factory dimension of 26* to the aftermarket dimension of 24*.
Hope this helps,
Uncle Charlie
Hope this helps,
Uncle Charlie
c.evans- BBF VENDOR SPONSOR
Thanks, Charlie That's what I needed to know.
1FastZ28- Posts : 3
» Boss 429 conventional head gaskets
» Total seal conventional rings
» Looking for conventional valve aluminum heads
» External oil pump -- Converting a conventional wet sump oil pan
