using aftermarket and factory fuel pumps
using aftermarket  and factory fuel pumps Empty using aftermarket and factory fuel pumps
Post  duff429 January 12th 2011, 7:04 am
Say a guy has a 600+ hp motor and and the factory fuel pump isn't keeping up, and wants to run a electric pump but still keep the factory pump on the block to appear factory. Would you gut the factory pump or use both? Or do most factory style and looking fuel pumps do ok on say a 600+ horse motor? Just wondering
duff429
duff429
using aftermarket  and factory fuel pumps Empty Re: using aftermarket and factory fuel pumps
Post  dfree383 January 12th 2011, 8:10 am
You can run a electric pump thru the Factory pump, the factory pump the becomes an extra thing.
But IMO it would be better to remove it / block it off and run larger lines, the factory stuff is pretty small for anything building and HP.
