Need a C6 to handle 1500hp
John I.
whitefield
Greg_P
EVE
Before anyone says anything I already have a glide. I have a 2wd C6 sitting here that I need to make handle 1500hp. The reason I need a 3 speed is because the new project weighs about 4500lbs and is 4x4. I'm afraid the glide won't launch hard enough with a street converter.
So what do I need to order for this C6 or who do I send it to?
EVE- Posts : 124
Re: Need a C6 to handle 1500hp
Broader Performance.
Greg_P- Posts : 1009
Greg_P wrote:Broader Performance.
I'm calling them right now.
EVE- Posts : 124
you should get colormebad to build you a C4................
Buy one of Franks Valvebody and put you a the red Alto clutches and rollerized and you be good to go!
whitefield- Posts : 2244
richter69 wrote:you should get colormebad to build you a C4................
That would last about .2 seconds off the brake until I got to see the top of the case come by my helmet at mach 5.
Seriously though, I need a 3 speed that will live behind 1500 horses in a 4500lb vehicle. The turbo stuff has been sold and is being replaced with a Procharger. It's all going into a new chassis that I promise will be way more unique then my old Mustang. I might have a TH400 lined up so that's another option.
EVE- Posts : 124
EVE wrote:richter69 wrote:you should get colormebad to build you a C4................
B.S.on the Th400! The c-6 will work in this set up! I talked to Frank Saturday and he is running 1650 hp thru his C-6 and over 150 passes a year.
You will need an aftermarket input shaft too. Line pressure will have to be high enough that you'll probably have to upgrade the pump sealing rings to seals. Frank knows all of this stuff, he'll come on and tell you what you need as soon as he's done shovelling snow.
John I.- BBF CONTRIBUTOR
whitefield wrote:EVE wrote:richter69 wrote:you should get colormebad to build you a C4................
YEH! Frank will fix ya right up. OH! and if ya wont a take a ride and see I'm sure he'll put that video back up...come on Frank you know you wont to show it agin
res0rli9- BBF CONTRIBUTOR
Here's one that will take it....Its Franks and he will make you one just like it.
https://s58.photobucket.com/albums/g266/fmerkl/?action=view¤t=incab.mp4
Frank ?
Who is this Frank you speak of?
How would someone get ahold of him?
Fatback- Posts : 61
Fatback wrote:Who is this Frank you speak of?
Frank Merkel, he's on the Forum here....... https://www.429-460.com/u57
Have Frank M build your trans . better hurry planting season not to far off
DanH- Posts : 1081
