Going to the races
Going to the races
I am fixin to head out to help my uncle run his mud truck for the first time, It is not a ford, but still Bad AZZ, it is 636" all glass, 1350on motor + the Spray and truck wieghs about 2450, since the last time he ran it he swicthed bodys styles, and lost 1000#'s+ and added a little more of the N20, thius is what it use to look like
It now has a 2008 nascar truck body on it, I will hopefully have some Video to post late tonight or in the morning
Edit I forgot to mention that it ran a 2.9 sec in a 160' with out the spray and burnt first out of the glide so if every thing goes as planed then it will be cool, He just put a new ring and pinion in it since when he tried it out in the field it ate every tooth off of the ring, and when he launched he yanced the front tires of the ground about 3 foot, and ran 180 on dry gound in 2.2 sec
Last edited by 77mud on July 4th 2009, 8:47 am; edited 1 time in total (Reason for editing : adding more Details)
Old blue Racin Team- Posts : 1579
Re: Going to the races
have fun and good luck and be safe
I'll bet that thing wil rattle your cage with that kinda power
56Tbird- BBF CONTRIBUTOR
Well they made the pit a full 200 feet and brought in 12 loads of true swamp mud, he ran a 3.1 on paddles, 3.9 on dot's and cuts, we ended up with a 1, 3, 4 place finishes, I will have alot of video's and pics to post in the mourning, It time to go to bed
Well here is what the truck looks like after 2 years of modifying
Naughty Driven by Gary Cannon
Here are a few video's
Pass made with Cut's No Spray, Keep in mind this is the First pass that he made with the truck after redoing it
And a Dot pass No Spray
And a Paddles Pass A small tune of the Spray
On a Rampage Drove by Ed Ipok
Cut's
Dot's this is How Nast the Pit was
And the Paddles Class Running the Cuts Again
Orange Blossum Special Drove by Critter
The 48 F-1 Cuts pass
And the Dot Class
And the Paddles class running the cuts again, He did actully break the Timers
And the Dot Class
Pony Express Driven by Jim
Here is the Little Bronco 2 with a stock 4.0 and 36's
at the end of the night
Gary ended up with First in Dot's, Third in Paddles, and Fourth in Cuts
Ed ended up with Fifth in Paddles, Fifth in Dot's, and Seventh in Cuts
Critter ended up with Third in Dot's Fifth in Cuts, and Sixth in Paddles
Jim ended up with Third in Street
» Off to the races..........
» Took a knife to a gunfight............
» car / bash
» I'm off to the races.......
» I'm back from the track!! Aaaand.........
» car / bash
