Turbo help what turbo do I have
jones
Bigblockfox
A buddy gave me a turbo off of a 350 cummins. What size turbo is it? Thanks
Bigblockfox- Posts : 47
Re: Turbo help what turbo do I have
It looks like this one. http://www.ford-trucks.com/forums/634074-so-i-got-a-turbo-well-two-actually.html
about a 76mm. dinosaur of a turbo. very inefficient for a gas motor.
whatbumper- Posts : 3024
My brother uses the turbos off a 5.9 Cummins for is Honda engines. I want to say those are 56mm Holsets.
jones- Posts : 2230
whatbumper wrote:about a 76mm. dinosaur of a turbo. very inefficient for a gas motor.
So it would work on a stockish 460?
I would not go through all that work for so little gain.
bbfhnj- Posts : 13
that does seem like a lot of work and b.s. for an old used turbo that you dont have any real specs on. Plus, unless you know the history, that thing could have a half million miles on it and let go at any time.
Unless you just want to experiment.
AK- Posts : 67
Bigblockfox wrote:whatbumper wrote:about a 76mm. dinosaur of a turbo. very inefficient for a gas motor.
the map would be awful on a gas burner. remember they were built to run on 1800-2200 rpm engines.
4 of them might work decent on a stroker engine. I've actually been debating it.
whatbumper wrote:Bigblockfox wrote:whatbumper wrote:about a 76mm. dinosaur of a turbo. very inefficient for a gas motor.
EVE- Posts : 124
hmmm. I would hate to see the piping.
whatbumper wrote:hmmm. I would hate to see the piping.
I have plenty of room in the new truck but I'm thinking twin 88's or S480's are going to be better for me.
EVE- Posts : 124
After more researching I found that the t46 was replaced by the ht3b. This turbo is rebuilt and has no shaft play in it. Im wanting to run it in a fox with a mild 460. Dont want a race car just something different. Will this turbo support 600hp? If things need to be changed what are they? thanks
Bigblockfox wrote:After more researching I found that the t46 was replaced by the ht3b. This turbo is rebuilt and has no shaft play in it. Im wanting to run it in a fox with a mild 460. Dont want a race car just something different. Will this turbo support 600hp? If things need to be changed what are they? thanks
You could get 600 horses N/A without even trying. Turbos are a pain in the rear to setup and unless your shooting for 1000 or more it's not worth it. This will be my 3rd turbo BBF engine so I'm speaking from experience.
EVE- Posts : 124
EVE wrote:Bigblockfox wrote:After more researching I found that the t46 was replaced by the ht3b. This turbo is rebuilt and has no shaft play in it. Im wanting to run it in a fox with a mild 460. Dont want a race car just something different. Will this turbo support 600hp? If things need to be changed what are they? thanks
Are they that hard to set up? I may just want to stick to N/A and nitrous.
it's not hard but a single turbo is not normally practical on that large of an engine due to backpressure issues with the large volumes of air that we are talking about in these engines. Y would have to keep your revs really low. It would make so much low end torque that it probably would not be fun to drive on the street.
whatbumper wrote:it's not hard but a single turbo is not normally practical on that large of an engine due to backpressure issues with the large volumes of air that we are talking about in these engines. Y would have to keep your revs really low. It would make so much low end torque that it probably would not be fun to drive on the street.
You coming up this year to run in wildstreet?
Bigblockfox wrote:whatbumper wrote:it's not hard but a single turbo is not normally practical on that large of an engine due to backpressure issues with the large volumes of air that we are talking about in these engines. Y would have to keep your revs really low. It would make so much low end torque that it probably would not be fun to drive on the street.
planning on it. trying to coordinate schedules. they are the last group to post their schedule. we are planning on two OTT5 races, all the TTT5 races, a couple WTTTF races and what ever will fit in between all those in wild street. hoping for a good year of racing. last year killed us. we are making a couple of changes; new ignition, new anti-roll bar, moving some weight around.
300 hp @ 4100 and 800 ft lb. of tq. @ 1900 rpm..................
