rings for pistons
+6
466bronco
AK
hpwdboss1
bigunitmudracing
10 posters
rings for pistons
are perfect circle rings any good... high compression motor what would u use... ??? NO NOS...
bigunitmudracing- Posts : 159
Re: rings for pistons
size and material that the rings are made of is a little more imprtant then the manufacture.........
Re: Rings
So...
With a standard ( 5/64-3/16 ) ring package and a 15.5 comp ratio on 118 gas, what ring material? <6k rpm.
Perry
Perry
hpwdboss1- Posts : 147
1/16 , 1/16, 3/16, rings.. 15:1 compression, 6500rpm max, 118 octane gas!!!
Last edited by bigunitmudracing on January 25th 2011, 6:10 pm; edited 1 time in total
bigunitmudracing wrote:1/4 , 1/4, 3/16, rings.. 15:1 compression, 6500rpm max, 118 octane gas!!!
sounds like you know everything you need..........
I may have to try some of those 1/4" rings too. Better oil control.
AK- Posts : 67
ok.. well i am wondering what rings to use with this engine combo! moly? filefit? total seal, what is nessisary for the application?
Imo file fit is the way to go,total seal is hard on the block too much drag,but will help with vacum.
466bronco- Posts : 23
looking for more opinions on piston rings... please
Just get a set of file fit rings from somebody like Speed-Pro or Akerly & Childs and go have fun.
Lem Evans wrote:Just get a set of file fit rings from somebody like Speed-Pro or Akerly & Childs and go have fun.
And there's your final answer! A good plasma-moly file fit ring will last a long time as long as you set the gaps properly!
kjett- Posts : 1169
trying to find rings isn't working for me...
on summit or jegs..
4.420 file fit... unless i'm screwing up somewhere...
1/16, 1/16, 3/16
Sealed Power ZR9374065 - Sealed Power File-Fit Plasma-Moly Piston Rings - the only set i can find....
good enough for a race engine with high compression??
on summit or jegs..
1/16, 1/16, 3/16
If you wish, call our guy Shawn on parts......he can get you what you need. 270-278-2376.
Total Seal CRL2690-65. Works good
72puller- Posts : 105
Lem Evans wrote:If you wish, call our guy Shawn on parts......he can get you what you need. 270-278-2376.
^^^ this ^^^
138- Posts : 1593
Akerly &Childs 1/16 1/16 3/16 file fit ,from a vendor called BFEvansraceparts.com. you can't go wrong w/price and service.
» 460 Stroker pistons/rings set 521" + .030
» NEW 545 pistons with Total Seal rings
» Speed pro/TRW L2404F .030 pistons and rings
» New Diamond pistons w/ rings and pins
» New Diamond + 11 dome pistons w/ rings and pins
