I would like about
KY JELLY
I would like about
5 minutes in a 6 x 6 room with the rocket scientist engineer that designed the heater blend door motor on an 05 explorer.
KY JELLY- Posts : 1530
Re: I would like about
haha yeah mine broke years ago....but I fixed it..................I should sell the ideaI used to them bastards for like 1.2 million..............then I can quit this shithole...............KY JELLY wrote: 5 minutes in a 6 x 6 room with the rocket scientist engineer that designed the heater blend door motor on an 05 explorer.
PLASTIC TRUCKS!!!!!!
That should be recalled , that is stupidest thing I have seen engineered by an auto company.
You tube is your friend though saved me lots of trouble
It is an easy fix Randy. Pull the fan motor out, poke your hand up there and hold the door against the outside air intake. If you look on the side of the heater box near the dash there is some vents for the inside air intake, take a drill and long extension, poke it through the side vents and run two screws through the door into the case. You need to get very close to the edge of the door and I just used 3/4 drywall screws to hold it in place. It took about 15 minutes once I figured out what I had to do.
jasonf- BBF CONTRIBUTOR
the gear was just stripped on this one on the heat selection door
KY JELLY wrote:the gear was just stripped on this one on the heat selection door
Oh that sucks. Is that the one you need to remove the entire dash or cut the side of it out? Scary stuff right there.
He'd kill you Randy.
61coon- Posts : 1824
same guy put heater core in a fox mustang too! they suck but have you ever worked on a Toyota? they realy realy suck!
those all are tough but you should try 1 in a 03 cadi deville mode door actuator after your boss takes it apart and pulls all 3 door levers out and lays em in the floor and says fix it cause i cant , 3 hours on my head
its a good thing I`M THE MAN
hillbillyerv- BBF CONTRIBUTOR
