Used Billet Fabrications 2-Piece Aluminum Pan for 3-stage Dry Sump
Billet Fabrications 2-piece Big Block Ford oil pan setup for an 3-stage dry sump. Pan had a rod go through the bottom. Pan has been repaired, as the pictures show. Pan was on a 632-inch twin turbo engine, which is the reason for the dual -12an male fittings in the pan, which were for turbo oil drains.
Paid $1,100 for the pan. Will take $550 obo plus shipping in its current state. Pan only had 61 runs on it.
Thanks,
Brian Brown
601.218.3848
brian@quicktimemotorsports.net
Thanks,
Brian Brown
601.218.3848
Brian Brown- Posts : 34
Re: Used Billet Fabrications 2-Piece Aluminum Pan for 3-stage Dry Sump
$500 obo.
Thanks,
Brian
Thanks,
Brian
» 5 STAGE DRY SUMP OIL PUMP
» Blue Thunder Two-piece Cast Aluminum Intake with Valley Tray (Converterd to EFI)
» CNC Billet Aluminum 427 FE Engine Block vid
» New 1/2" Billet Aluminum 8 Lug Wheel Spacers
» Billet Aluminum C6 Direct drum
