Rocker stud torque?
Rocker stud torque? Empty Rocker stud torque?
Post  jbozzelle February 8th 2011, 10:37 pm
What do the rocker studs need to be torqued to? P51 head, standard stud that comes with it.
Rocker stud torque? Empty Re: Rocker stud torque?
Post  bb429power February 8th 2011, 10:43 pm
If the studs are anything like my ARP's 55 w/ moly and 70 w/ motor oil.
bb429power
bb429power
Post  Lem Evans February 9th 2011, 10:36 am
65ish with loctite is what i use on an aluminium head.
Post  richter69 February 9th 2011, 10:47 am
Lem Evans wrote:65ish with loctite is what i use on an aluminium head.
X2
Post  jbozzelle February 9th 2011, 11:29 am
Lem,
I'm guessing you did this to mine when I purchased them from you? I pulled the rockers off last night. I set up the valves and forgot to put on the nuts/locks for use with the stud girdle. So before I do that I wanted to check the rocker studs. I didn't remove them when I popped the valves out for a good cleaning before final assembly.
