ring gear replacement
ring gear replacement  Empty ring gear replacement
Post  frank13 February 19th 2011, 1:29 am
I have a PRW flywheel on the motor , ring gear is toasted. figured out it is a 180 tooth flywheel,
quicktime says the flywheel size for motor and trans should be 184t. I assume this is the reason I am killing starter gears and the ring gear.
ok so now for the questions:
can i replace the ring gear (billet steel flywheel)
If i can repalce the ring gear, can i replace it with a higher tooth count. (180 to 184t)
thanks
frank13
frank13
http://www.frankskinkracing.com
ring gear replacement  Empty Re: ring gear replacement
Post  342g February 19th 2011, 3:10 am
Frank, I think all the big block internally balanced engines takes a 184 tooth flex plate, you need to talk to one of the hero type guys, all I've had are 184.
Ignore this Frank, I just seen on the for sale section you are running a stick shift., SORRY
342g
342g
Post  frank13 February 19th 2011, 10:40 am
no one?
frank13
frank13
Post  DanH February 19th 2011, 10:50 am
must likely thats offshore fly wheel . nothing to lose , take off the ring gear and get a 184 and see if it fits
DanH
Post  frank13 February 19th 2011, 2:34 pm
ok so i found some specs on the ring gears:
184t outside diameter 15.503"
inside diameter 14.210"
180t outside diameter 15.512"
inside diameter 14.518"
am i missing something, shouldnt the 180 be smaller than the 184 ring gear? what am I missing here....
frank13
frank13
Post  DFI429 February 19th 2011, 3:03 pm
The OD is only .009 bigger - .0045 on a side.. meaningless really. Being that the OD is a negligible difference, that means the 180T is slightly coarser to get the same diameter. If they were the same pitch, you're right - the diameter would be smaller. As far as the ID, that's just the finish size to fit the flywheel register. Not sure why there would be a difference there.
Hope this helps!
DFI429
DFI429
Post  frank13 February 19th 2011, 3:08 pm
the pitch of the gear is the same between the two. I was hoping to pop a 184 ring gear on the 180 flywheel i have, but it looks like i am buying a new 184t flywheel.....
frank13
frank13
Post  DFI429 February 19th 2011, 4:06 pm
If the pitch is truely the same, and the OD is the same, the pitch diameter is smaller, making the teeth deeper, and chewing up your starter. That's odd, as it would make the tips of the tooth form 'thinner'..
At any rate, the register for the ring gear you need is smaller, so unless you made a spacer ring, it ain't gonna happen Wink
DFI429
DFI429
