help with a pos chevy
Bigshank
help with a pos chevy Empty help with a pos chevy
Post  Bigshank February 21st 2011, 6:30 pm
I have a 93 chevy suburban w/ 350 tbi injection. It will idle great when i pull into gear it acts like it has a miss in it, will stay running for about 5 to 10 mins.Then it dies and will not restart but smell flooded bad when i try to start it . I have changed map sensor w/new, and the tbi was switched out w/ diffrent one and full up tune plugs,wires, cap and rotor ,check all vac system still the same. PLEASE any ideas would greatly helped Mad
Bigshank
Bigshank
help with a pos chevy Empty Re: help with a pos chevy
Post  IDT-572 February 21st 2011, 6:35 pm
Bigshank wrote:I have a 93 chevy suburban w/ 350 tbi injection. It will idle great when i pull into gear it acts like it has a miss in it, will stay running for about 5 to 10 mins.Then it dies and will not restart but smell flooded bad when i try to start it . I have changed map sensor w/new, and the tbi was switched out w/ diffrent one and full up tune plugs,wires, cap and rotor ,check all vac system still the same. PLEASE any ideas would greatly helped Mad
You got insurance ? If yes, put a match to it................... and buy a ford Twisted Evil
Post  bbf-falcon February 21st 2011, 6:36 pm
Mark,have you done a fuel pressure check and possibly a fuel filter change. Fuel issues can do strange things.
Post  maverick February 21st 2011, 6:49 pm
Sounds like O2 sensor trouble to me.....Had a GD Buick with TBI that acted just like that.
Post  DanH February 21st 2011, 8:08 pm
puy a timing light on it . if timing all over the place , pickup in dist is bad . or the dist shaft weld broke
DanH
Post  maverick February 22nd 2011, 10:03 am
maverick wrote:Sounds like O2 sensor trouble to me.....Had a GD Buick with TBI that acted just like that.
After I changed out the O2 sensor, it had to run for a couple minutes before it straightened out, so don't be fooled.
Post  bb429power February 22nd 2011, 5:20 pm
Just curios, does this engine have an altitude sensor Question My buddies truck was running rich and was acting funny and I changed the vacuum lines up (helped because they weren't in the right spots), did the 02 sensor (did a little), changed the idle sensor or something like that (helped a little). Then he was at his girlfriends house, and it started doing the same thing as what you said and he had to leave it there for a couple days. Anyway, he ended up changing this altitude sensor on it and it runs great now. Who'd a thought it was that??? Not sure where its located...But it couldn't hurt to give it a shot if yours has one Smile
bb429power
bb429power
Post  Bigshank March 1st 2011, 8:03 pm
Dan H is the winner. Needed a distributor and coil, Dan thanks again for helping me out. cheers
Bigshank
Bigshank
Post  bbf-falcon March 2nd 2011, 9:31 am
Glad you finally got it Mark,I know you have been fightin that thang for awhile Smile
