CAST IRON EXH.
mitch
Rvesterby
ROAD RAGE
CAST IRON EXH.
Looking for a set of Cast Iron SCJ Exh Manifolds.
Please Pm the price and detailes. Thanks..........
Ed.
Ed.
ROAD RAGE- Posts : 229
Re: CAST IRON EXH.
Mustang or Torino?
Re: CAST IRON EXH.
Sorry Dave,, I should of been more Specific.
There to go in a 79 f-350 4x4.
It will depend on where they exit......Thanks.
Re: CAST IRON EXH.
Torino ones have a turn-up on the Driver side outlet, mustang ones come down at an angle, they are the same on the passenger side. Either should work on a truck.
This is a Torino one
Re: CAST IRON EXH.
not real sure,, but it being turned up on the driver side, might have issues with the clutch linkage.
Thinking the ones that are angle down would work.
Just checked (eye balled) looks like the drivers side does need to be angled down to clear the clutch assy.
(cross tube from frame to bell)
Re: CAST IRON EXH.
Pic of a Mustang Drivers Side one.
Pic of the Common Passenger side one.
Re: CAST IRON EXH.
heres a set on Flea bay
http://cgi.ebay.com/ebaymotors/429-Super-CJ-CJ-Mustang-Torino-Exhaust-Manifolds-_W0QQcmdZViewItemQQhashZitem3cb561fc0eQQitemZ260741135374QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
CI Exhaust
Change the motor to a FE - I got a set of FE cast iron headers I need to sell .............smile
Got a set of 429 CI manifolds on my blue 71 Mach1 - but think I need to keep them
Good luck
Good luck
Rvesterby- Posts : 130
FYI
Maybe Dfree can verify
But as I recall Over the years the right or passenger side seemed to crack from heat and contraction more so than the drivers side
So be carefull purchasing
Re: CAST IRON EXH.
Thanks, the ones on e-bay were nice, I bid, but wasnt quick enough..
Re: CAST IRON EXH.
I was quick enoughROAD RAGE wrote:Thanks, the ones on e-bay were nice, I bid, but wasnt quick enough..
You probably could use police interceptor manifolds too, they are about the same as CJ's
mitch- Posts : 116
Re: CAST IRON EXH.
Rvesterby wrote:Maybe Dfree can verify
Yep..........
PI exhaust manifolds
If you are still looking for some I have a set. They are PI manifolds not SCJ.
tiger- Posts : 272
Re: CAST IRON EXH.
How about using the medium duty truck manifolds ?
posford- Posts : 90
Re: CAST IRON EXH.
I think those heavy duty truck manifolds that come in the f-700 trucks will only work with a front plate and only work on the late 1970's truck frames. Correct me if I am wrong.
tiger- Posts : 272
Re: CAST IRON EXH.
ROAD RAGE wrote:Sorry Dave,, I should of been more Specific.
i didnt read this whole thread,but you will have to trim the top part of the r/h frame rail
BOSS 429- Posts : 2372
Find yet?
See here:
http://www.kijiji.ca/v-engines-and-engine-parts/saskatoon/nos-ford-ex-manifolds-428scj-429scj/451759006
An NOS D2OE-9430-CA RH passenger exhaust manifold correct for 429PI engine & service replacement for 429SCJ Cyclone, Mustang, Torino etc. Genuine Ford NewOldStock item. Sorry, no matching LH.
djjsc- Posts : 3
» CAST IRON EX 514 HEADS
» Cast iron RHS 460 head?
» Aftermarket cast iron heads
» WTB: 65+ 427 Cast Iron Headers
» early cast iron rocker arms
