Valve bowl pocket dia
Valve bowl pocket dia Empty Valve bowl pocket dia
Post  72mav September 3rd 2009, 10:28 am
Whats common for a CJ 2.25 & 1.75 valve?, bowl diameters, that is?
Also whats a good reliable valve job spec for a steel heads?
Thanks.
Al
72mav
72mav
Valve bowl pocket dia Empty Re: Valve bowl pocket dia
Post  ThndrChkn September 3rd 2009, 10:55 am
The one's I've done, I just do a nice clean-up in the intake bowl and try not enlarge it anymore than the clean-up allows... On the exhaust side, I do all of them around 82% of the valve diameter, unless it's for a N2O app, then I've taken them to 85% and they seem to work very well... The exhaust lost a little bit of flow, but on the track it picked up some over the smaller bowl when used with N2O... Just my experience...
Doug... Cool
ThndrChkn
ThndrChkn
Post  72mav September 3rd 2009, 1:19 pm
Thanks Doug,
I need to get over to Scottys. Its probably over there. Thought about it after I posted this. Thanks.
Regards.
Al
72mav
72mav
Post  mach1charlie September 3rd 2009, 2:22 pm
87% max imo. An I like to radius ex. valve face
mach1charlie
Post  rmcomprandy September 3rd 2009, 6:21 pm
It all depends upon HOW you are gonna use 'em. Everything has it's limits, one way or the other.
2.06" on the intake is a good bowl dimension for a 2.250" valve when used on a race engine but, a little to large for a lower RPM or street driven vehicle.
For a 1.75" exhaust valve, the normal size is 1.50" to 1.54" for a closed exhaust and 1.60" for an open exhaust; (bigger for supercharged, nitrous or high RPM engines).
Post  72mav September 3rd 2009, 9:27 pm
Thanks for the replies guys, Good info. Keep it here!
Regards.
Al
72mav
72mav
