ignition questions
ignition questions  Empty ignition questions
Post  Maddmattmustangs February 27th 2011, 4:21 am
when should i start thinking about upgrading from the MSD 6aL boxes to the 7 series stuff?? confused
im going high compression, large cam, good heads and the like, so should i start looking into the 7 stuff to deal with the new demands of the engine?
Maddmattmustangs
Maddmattmustangs
ignition questions  Empty Re: ignition questions
Post  LivermoreDave February 27th 2011, 8:37 am
For what my opinion is worth, the MSD 6 Series ignition boxes will go a long way! I think a few considerations in deciding to "step up" to a MSD 7 Series ignition box would be high compression and/or high engine speed. There are other considerations like cylinder pressure levels and fuel volume inserted into the combustion chamber. In layman's term, if the candle tends to go out, you need to turn up the wick!
Just mu $0.02!
Dave.
LivermoreDave
Post  schmitty February 27th 2011, 3:13 pm
How much C/R, and how fast? If in doubt, you probably need a 7 series iginition. Cool
Post  Maddmattmustangs February 27th 2011, 10:52 pm
13.3:1 comp and in the 10's Very Happy
Maddmattmustangs
Maddmattmustangs
Post  schmitty February 27th 2011, 11:12 pm
Should have worded that better, how many RPM's?
Post  56Tbird February 28th 2011, 12:44 am
I've ran mine at 16 to 1 and 7200RPM with a 6AL and a 7AL3 at 8.70's..Couldn't tell any difference with either box ?I'm not sure how far you got to go before it matters?
56Tbird
56Tbird
