CHANGING OIL IN MY 6.0???
Hey guys, I'm fixin to change my oil . It's the first time that I myself have changed it. When I replace the filter on top of the motor, do I need to pour any new oil down in there, or just pour all of it in the valve cover? Thanks in advance.
scottke- Posts : 970
Re: CHANGING OIL IN MY 6.0???
If it like the 6.4 on top make sure you take the filter out first.When you pull the old oil filter all the old oil drains in the pan and out the drain plug.I learned that the hard way.On the 6.4 I pour oil in and screw the top back on in a hurry so it all don't drain to the pan.Like I said this is on a 6.4 don't know if the 6.0 is the same way or not.
Jim
Jim
Go it done, fuel filters and all. Boy the fuel filter on the frame is a muther freaker!
Don't even get Fabio started on the fuel filterscottke wrote:Go it done, fuel filters and all. Boy the fuel filter on the frame is a muther freaker!
bb429power- Posts : 3129
It's best to change the fuel filter on an empty tank with the truck facing uphill. Otherwise it'll just siphon the tank and make a mess. Watch out on what filters you use too. Some oil filters are too short and leave the drain valve open causing the oil to not get filtered.
jbozzelle- Posts : 3705
I used an Amsoil, it was the same length as what I took out.
You're OK.
Cool, Thanks.
You think the bottom filter on the 6.0 is bad........................take the same f-cked up idea a put a big ass wire harness right behind the filter where it wont come out unless you get a prybar after the son of a bitch.............
the dude that dreamed up that clusterf-ck needs an ass whippin'................
» Changing Over to new site! WOW
» changing fluid
» changing 9" lug patters
» Not what the changing rooms are for... LOL
» Changing Jobs???
» changing fluid
» Changing Jobs???
