Tell us your routine
+16
JACKAZZFLATZ
patfromjersey
56Tbird
nuclearcobra
LivermoreDave
'65 T-BOLT
knrclark
342g
bb429power
BigDave65
bigblockfox468
20 posters
Page 1 of 2
Page 1 of 2 • 1, 2
When you get to the track to run....like what do you do, check, how do you warm up, how long,etc. etc. etc.
Re: Tell us your routine
I figure all the "checkin'" (at least to start with) should have been done in the garage. I think it's silly to trailer a racecar to the track, unload it and take it apart. I figure that's what weekdays are for.
I drive the car through the pits to circulate fluids (rear end) and warm the engine to about 180*. Most important to me is to get some heat in the oil. Flogging a cold engine (or one with cold oil) is a no-no for me. Not too much heat in the 'glide, though. A cool trans is a happy trans. Tire pressure is last thing to check before a pass.
maverick- BBF CONTRIBUTOR
I do pretty much the same thing as Maverick. About an hour before my first practice run, I'll make a couple laps around the pits with just the water pump running, get it up to 180*. Get back to pit and turn off water pump and let it just cool down slowly. Hook up battery charger, make sure all 4 tires have enough air in them, fuel up and wait to make first run. I usually make 1 practice run, run the dash-for-cash, then go into first round. I wouldn't even pull the hood if I didn't have a front mounted fuel cell, not until later rounds at least.
BigDave65- Posts : 567
maverick wrote:I figure all the "checkin'" (at least to start with) should have been done in the garage. I think it's silly to trailer a racecar to the track, unload it and take it apart. I figure that's what weekdays are for.
I agree with what you say in your first paragragh first.
I was actually looking for what you said in your second paragraph and what bigDave has said also. This Snake engine I now have I've never had anything like it before . I just want to make sure I'm treating it right before I drive like I stole it so it treats me right .
That's a good idea about getting the axle warmed up, I will have to do that next time I race. That may be part of my posi problem...
bb429power- Posts : 3129
I plug the heaters in and go to the snack shack.
Curt- Posts : 2791
As soon as I park the rig I fire up the genny and plug the block and oil pan heaters in, unload everything, jack up the rear and by then its good and warmed up. I run the motor (on gas) and warm the trans fluid, diff etc, work t brake a few times............as stated not much to check as its all done before we go.
top off fuel, check tire press, drag it to the lanes and let it rip..........
richter69 wrote:As soon as I park the rig I fire up the genny and plug the block and oil pan heaters in, unload everything, jack up the rear and by then its good and warmed up. I run the motor (on gas) and warm the trans fluid, diff etc, work t brake a few times............as stated not much to check as its all done before we go.
i JUST LET THE PIT CREW DO EVERYTHING, THEY SAY i GET IN THE WAY, SO i DRINK COFFEE, AND TURN ON THE WIN LIGHTS.
342g- BBF CONTRIBUTOR
Warm up
Basically same as everyone else. Drive around on gas warm and circulate everything. I have found that if I run my car without a warm up it falls on it's face. After warming up top off fuel and check air pressures before first pass.
knrclark- BBF CONTRIBUTOR
me too! if i'm late i'll go to the lane and let it run while i wait my turn.now that i have alky i'm one of those assholes that chokes everybody.BigDave65 wrote:I do pretty much the same thing as Maverick. About an hour before my first practice run, I'll make a couple laps around the pits with just the water pump running, get it up to 180*. Get back to pit and turn off water pump and let it just cool down slowly. Hook up battery charger, make sure all 4 tires have enough air in them, fuel up and wait to make first run. I usually make 1 practice run, run the dash-for-cash, then go into first round. I wouldn't even pull the hood if I didn't have a front mounted fuel cell, not until later rounds at least.
mine is all warmed up from driving it to the track! about 7 miles!! check air pressures and let r eat!
'65 T-BOLT- Posts : 1464
Curt wrote:I plug the heaters in and go to the snack shack.
Curt and I start our day at the track about the same! Then after a few minutes of enjoying the "track food", it happens, a mad dash to the restroom! Now I'm just getting comfortable in the rest room and I hear the announcer, " drivers in your cars and buckle up"! What the hell? What happen to first, second and final call to the lanes? Must been announced during the excitement of recycling the track food! Have you ever noticed how the track rest rooms sound like a thunder storm has moved in or does everyone enjoy "track food" first thing at the track?
Dave.
LivermoreDave- Posts : 972
Wow sounds like your track only serves mexican food
nuclearcobra- BBF CONTRIBUTOR
Sounds like IBS....Irritable Bowel Syndrome. Track food usually stops me up like a kick in the 'nads stops everything.
Go to track ....Run as many time runs as possible...Race...Get Check..Go again tomorrow ...Work on car ALL week
56Tbird- BBF CONTRIBUTOR
Nice Dan; that's pretty much how it goes for you.
Harold, you forgot the part how Mark will cook the steaks, before he checks your tire pressure.
patfromjersey- BBF CONTRIBUTOR
I check everythnig before we go. Unload the 4 wheeler and car and warm it up by driving it around a bit. I check air pressure right before running. After making a few passes and fiinding out exactly what the car will do with whatever changes I have made, I start to get jealous because Ellen is on her 4th beer, and I haven't had any. Then I make it through too many rounds without being eliminated, and start to get irritated because Ellen is on her 9th beer, and I'm still sober. Finally I get eliminated and the party starts when we get home.
cletus66- Posts : 865
Too funny Jeff. I still remember that first Bash you and Ellen went to, and my father and I had such a great time with you two. I was surprised Ellen still had her ears on when she left, because I thought Dad talked them off.
patfromjersey wrote:Nice Dan; that's pretty much how it goes for you.
You are right, I forgot that part, but I could not see him, I was at Rick's trailer drinking Coffee with Sooz.
patfromjersey wrote:Too funny Jeff. I still remember that first Bash you and Ellen went to, and my father and I had such a great time with you two. I was surprised Ellen still had her ears on when she left, because I thought Dad talked them off.
That was the first time my car ever rolled on asphalt. We were still putting it together in the pits. We hope to be back eventually.
Youse guyz have food at your track ???
We've got free range hogs on the other side of the back fence.!!.
ALWAYS let my junk warm up. If'n it dont, the first time trial is a give away. Everything is too cold to be consistent.
JACKAZZFLATZ- Posts : 249
come down to Milan more often you've been there, there are about 10 food standsJACKAZZFLATZ wrote:Youse guyz have food at your track ???
quote="JACKAZZFLATZ"]
Thats a FACT Jack
Thats a FACT Jack
bb429power wrote:That's a good idea about getting the axle warmed up, I will have to do that next time I race. That may be part of my posi problem...
posi? get rid of the chevy rear,lol
BOSS 429- Posts : 2372
Hecks yeah, you the man Harold!!
D's557BBF- Posts : 1186
Page 1 of 2 • 1, 2
Page 1 of 2
