SBF heads needed for 302 street motor
whatcha got? open to any ideas. Building a little 302 for a friend.
BB94STANG- Posts : 249
302 heads
I have a set of 302 heads fresh from machine shop. Valve job, seals, non stock springs (from hydro perf street cam), ex port gasket matched and hump removed. Intake ports gasket matched for the first 3/4" into port then just touched up any flashing. Face resurfaced. Stock rockers. Fresh Ford Blue. Ready to install.
In 1979 I bought and I personally pulled the 302 out of a 1968 Shelby that these heads were on. I don't believe they were special that year and don't know how to verify, just thought you might like to know.
Asking $600 delivered to 48USA. Pictures wanted? Send me your email
bowsher21- Posts : 100
Re: SBF heads needed for 302 street motor
Branden,do you want a aftermarket head or just a 302 head? I have some stock ones.call me
bbf-falcon wrote:Branden,do you want a aftermarket head or just a 302 head? I have some stock ones.call me
Really lookin for a gt-40 head(explorer) iron. he has a super strict budget.....just looking for 275-300hp, I think some gt40's and a upgraded hyro roller will get him close. I'm going to do a stock rebuild bottom end with just an upgraded head/cam/header combo so it should get him close. I'll b in touch Rick
Brandon the explorers had gt40P heads on them
the Coug- Posts : 3055
the Coug wrote:Brandon the explorers had gt40P heads on them
Their are some with the regular GT40's too Coug. Depends on what they had avaliable. But Most are the P heads.
Thanks Coug. The P heads will be ok too. I think I'm headed to the salvage yards today.the Coug wrote:Brandon the explorers had gt40P heads on them
P's work great for a factory Iron head. Just Check header to Plug Clearance, some headers get a little too tight because of the plug position on the P's.
Double Post....
BB94STANG wrote:Thanks Coug. The P heads will be ok too. I think I'm headed to the salvage yards today.the Coug wrote:Brandon the explorers had gt40P heads on them
Brandon I took a brand new set to the machine shop a couple weeks back and had cut for bigger valves.... now going to clean up and put on wifes 347....
Will do. Thanks Dave.
the Coug wrote:BB94STANG wrote:Thanks Coug. The P heads will be ok too. I think I'm headed to the salvage yards today.the Coug wrote:Brandon the explorers had gt40P heads on them
What do they run new Coug...can you still get 'em?
call Shawn and ask I got mine several years ago and I think I gave like $350 a pair new..... bare castings....
» needed SCJ heads
» Advice needed regarding correct starter motor to use.
» C-heads info needed
» Needed ASAP SCJ Heads
» SBF Heads, *NOT NEEDED ANYMORE*
