Barry Grant Fuel Pump
I have a Barry Grant 400 fuel pump that needs to be rebuilt. Is there anyone out there that can do it? I would hate to throw it away.
Re: Barry Grant Fuel Pump
I have one that needed to be re-built also so last year I send it back to BG...got it back and it was still bad!
valleydawg- Posts : 427
If the motor is still good and it's just leaking you can buy a seal/o-ring kit from Product Engineering and do it yourself.
http://www.product-engr.com/replacements.htm
They sell the specific ones for the BG pumps. Just grind a slot in the heads of the anti-tamper screws on the pump to remove with a screwdriver. Replace them with regular screws.
I talked too the owner at product eng. and he explained how to do it the right way,and it would be better than new.He will explain the leak problem and how too eleminate the problem.
That is the problem with mine...it leaks. Thanks for the tip...I was wanting to use it as a back up.
Naw, the motor is bad in mine.
» Barry Grant out of business?
» Barry Grant
» Barry Grant 400
» Tuning Demon Carb on Stock 460ci Pickup Engine
» barry grant blow
» Barry Grant
» Barry Grant 400
» barry grant blow
