MSD 7al3 with Crank Trigger
Setting the timming is a pain in the A** with this crank trigger. Can I set it at say 40* and then change it with one of the retard modules. The MSD directions are somewhat vage in this reguard. It says you must have zero modules installed or the corrspomding terminals grounded. I get that, but what would happen if I put a 8* module in, would I then have 32* and what triggered it ? I would like to change the timming via the box instead of moving the trigger, it very busy down there.
Thanks Mark
Thanks Mark
Re: MSD 7al3 with Crank Trigger
Yes you can do it that way. I have my trigger wheel set-up on 40* and I use a retard chip to set my timing. I use the zero chips as well as grounding the other terminals just to make sure they can't do anything. This is the best way to do it as far as I'm concerned. Just change the chip to adjust timing. I have verified the timing changes with each chip as well.
Nothing has to trigger it. It just sees which terminals aren't grounded or zeroed. You can put two 4* chips and it will still retard 8*. You can set up a high gear retard and trigger it with a relay or switch.
BigDave65- Posts : 567
also make sure you ck phasing on the dizzy
Now I am cornfused you dont have to trigger it but then you say you can trigger it? If you have chips in 3 of the spots how is it you only use 1 at a time? I thought you used 12 volts to trigger each chip.Nothing has to trigger it. It just sees which terminals aren't grounded or zeroed. You can put two 4* chips and it will still retard 8*. You can set up a high gear retard and trigger it with a relay or switch.
Had to read it a few times to figure it out...
OHHH got this, its grounded with a chip in it then take the ground away when you want it, not put 12 volts to it.
nitro717- Posts : 92
Thats right. You can have a 4* chip and it will retard 4*, you can have another 4* chip on a trigger to remove the ground and activate it. Without a trigger 2-4* chips will retard 8*. And like Bruno said you need to check rotor phase. It can cause some hard cranking issues or if you're spraying and pulling a lot of timing with 2 or 3 stages, the rotor phase changes and can actually move too far away from the dist. terminal.
» Crank trigger?
» aluminum crank pulley and a crank trigger
» msd crank trigger
» Crank trigger and DIS
» Crank trigger?
» msd crank trigger
