fresh breath
'65 T-BOLT
quick 52
fresh breath
has anyone try a cold air kit with a carb. any hp gains
dragweek quickest street rod
2009 2010
2009 2010
quick 52- Posts : 612
Re: fresh breath
Anytime that you can get colder air too a engine ,it is a good thing imo. BBF's especially like colder air
Re: fresh breath
I gained mph and et
'65 T-BOLT- Posts : 1464
Re: fresh breath
quote="'65 T-BOLT"]I gained mph and et[/quote] what kind of setup do u have
Re: fresh breath
I have a single 4 oval air bonnet (like the thunderbolts) with a pair of 4' tubes to the inboard headlights,with 6' to 4' reducer cones from an HVAC supply house
Re: fresh breath
Here is your answer ...scroll down about 1/3rd of page.
http://www.460ford.com/forum/showthread.php?t=148394&highlight=ram+air+breather
I made mine out of two stock 460 breathers, cut the bottom out of one and slide it inside the other till a 4 1/2x 13 5/8 element fit.
turn the top one so the whole for the hose is on driver side and weld. get the hose at home-depot or lowes. instant ram air
ps: My motor box is only 2"s all the way around the engine Soooooooo I probably gained 100hp
res0rli9- BBF CONTRIBUTOR
Re: fresh breath
There is a lot on this topic, but one positive factor of a "sealed to the outside" air intake is that the car will follow the information that you get from your weather station/ET prediction software with more accuracy. I feel that mixed "hot" underhood air is slightly more constant as ambient temperature changes.
So...if your weather station tells you that your car will speed up...or slow down....all of that information is based on the air outside of the hood or scoop, not what is heated by the radiator, headers and engine.
I know that it sounds weird....but if you think about it a little, it makes more sense.
I ducted the teardrop bubble hood that my 514 uses....to pull air from the grill area and the car became much more consistent with the information collected by my weather station and will do almost exactly what the prediction software says. My grille area became a giant scoop, also. Before, it was just using under hood air and whatever it saw from the rear screens on the bubble.
Just my observation on this.....
Keith
Keith
Re: fresh breath
I looked...no pictures of the air box on the car!
Re: fresh breath
Wheelie58 wrote:There is a lot on this topic, but one positive factor of a "sealed to the outside" air intake is that the car will follow the information that you get from your weather station/ET prediction software with more accuracy. I feel that mixed "hot" underhood air is slightly more constant as ambient temperature changes.
Keith
T/Y
342g- BBF CONTRIBUTOR
Re: fresh breath
Keith
I've noticed this as well Keith. I've seen a car get a sealed up scoop and it became really sensitive to weather conditions. I've always run an unsealed scoop and it seems to be more consistent throughout the day into the night time. It works for me anyway.
BigDave65- Posts : 567
Re: fresh breath
3 days on this forum, about 10 visits and already something to think about! Excellent!
peganit2- Posts : 55
» ACA tax now required to Breath
» 468 bbf fresh
» fresh 460 FS W/PIC's
» bbf 473 fresh
» 429 Fresh Rebuild
» 468 bbf fresh
» bbf 473 fresh
» 429 Fresh Rebuild
