valve covers
bigjohn2007
quick 52
valve covers
i have the ford motorsport valve cover and want to weld a bracket off of the corner. it would be 1"x 1 1/4" alum. bar stock to hold my nitrous and fuel log. it would bolt to the nitrous combine fuel log whitch is 1" round stock drilled from each end. nitrous one end fuel the other and drill and tapped on the 11" long side for solenoids. do u think vibration of the engine weaken the cover at the weld.
dragweek quickest street rod
2009 2010
2009 2010
quick 52- Posts : 612
Re: valve covers
I'd be more concerned about the engine vibrations effecting the regulators ability to regulate fuel properly.........
Re: valve covers
solid mounted engine ?
Re: valve covers
no the engine has stock mounts. but was now thinking about heat tranmitted thru valve cover to fuel log.
2009 2010
2009 2010
Re: valve covers
x2richter69 wrote:I'd be more concerned about the engine vibrations effecting the regulators ability to regulate fuel properly.........
bigjohn2007- BBF CONTRIBUTOR
Re: valve covers
If your engine vibrates that much,the regulator is the least of your worries
Re: valve covers
bbf-falcon wrote:If your engine vibrates that much,the regulator is the least of your worries
I guess that's why the prostock guys like to run rubber under the carbs and such...............it aint about it shakin like a Japan earthquake, those little ultrasonic vibrations every engine has is what'll dick with it..................
All the guru nitrous guys will tell ya to let the regs hang by the hoses............there is a reason for that...............
Re: valve covers
Don't call me a guru. Unless you say Mr. Guru!
Curt- Posts : 2791
Re: valve covers
GuRu.............there I spelled it right this time........
Re: valve covers
Re: valve covers
reg. not on the fuel log its shaking over on the inner fender. engine isnt rough its a mild build. not sure about weld the nitrous-fuel log to the valve cover. thinking heat may be a problem but it sure looks clean. this all got started when making a alum fan shroud needed a small peice of alum. while looking found the round stock wheel started rolling. shroud looks great buff the $hit out of it
2009 2010
2009 2010
Re: valve covers
well got started on my nitrous fuel log. build a jig to hold the bracket to the log so both bracket ears are the same. after playing with a few times iwelded the ear on. then welded the bracket to valve cover bolted the brackets together.WTF i welded the log bracket to the top instead of the bottom. pi$$ed off i left it on the work bench and went to dinner and a few beers. watching the grandkids today so tomorrow its back at it hope i can get it right the second time.
Re: valve covers
richter69 wrote:bbf-falcon wrote:If your engine vibrates that much,the regulator is the least of your worries
my shit hangs
Re: valve covers
[/quote] my shit hangs [/quote]
They make tolit paper for that Mr Bruno
Re: valve covers
richter69 wrote:GuRu.............there I spelled it right this time........
HeRo GuRu......
You wear a cape or a robe now?
Re: valve covers
are you calling the solenoid reg. or the regulator a reg. because my regulator is mounted to the inner fender. the solenoids will be mounted to the nitrous fuel log mounted to the valve cover
» valve cover studs for aluminum valve covers
» Sheetmetal valve covers
» 429 M/T valve covers
» valve covers?
» WTB: Mickey Thompson Valve Covers
» valve covers?
