'77 LTD 460 + ZF 5-speed in a '76 F-350 2WD
'77 LTD 460 + ZF 5-speed in a '76 F-350 2WD  Empty '77 LTD 460 + ZF 5-speed in a '76 F-350 2WD
Post  scrublie March 28th 2011, 1:40 am
Hello there and thanks in advance.
My main question is what clutch and flywheel I need to use, and if i should go hydro or mech linkage. If my homework is correct the '77 motor is internally balanced, and the ZF only came on the later ('87-'95) externally balanced 460's. Also any tips or suggestions that may help my swap go smooth would be greatly appreciated. This truck will be hauling a trailer almost daily. The 460 has 45k origional miles on it, all stock at this point. Some help with a Boneyard list, and a parts store list would be great. Thanks again.
scrublie
