got a question on a 460 waterneck
Ok, I'm putting in 16an fittings for radiator hoses. My problem is in the intake there is no provision for my temp guage fitting ( 1/2 inch npt ). does someone make a waterneck for a BBF intake with a provision to connect this fitting?
I've found what I need in jegs( http://www.jegs.com/i/JEGS-Performance-Products/555/53017/10002/-1?parentProductId=761020 ) , but they say for chevy and mopar. is the bolt pattern for a BBF and a bbc the same??
Thanks for any help guys.
scottke- Posts : 970
Re: got a question on a 460 waterneck
No the Ford bolt pattern is different. The bolts are closer together than the Chevy or Mopar. What about drilling and tapping the front face of your intake manifold, just below the water neck area? By front face I mean the part facing the radiator.
Charlie
Charlie
c.evans- BBF VENDOR SPONSOR
Hey Charlie, hows it going. Car is coming along good, barring anything crazy, I should be ready for the bash!
I thought about that, was hoping to find something that would work otherwise. guess I'll have to drill. Thanks.
Scott,
There is a flat area there, below the water neck, and there maybe already be one or two holes drilled in there. I have drilled and tapped in an AN-16 fitting in that area facing the radiator, and then made a block-off plate out of flat aluminum to cover over where the thermostat goes. Another option is just make a thermo block-off plate out of 3/8" thick alum. and tap it for the AN-16 fitting.
See ya' at the Bash!
Charlie
Charlie
» I HAVE MSD QUESTION
» 460 waterneck
» Cam question ?
» 4.6 question
» 460 waterneck
» Cam question ?
» 4.6 question
