demon e85 conversion
demon e85 conversion Empty demon e85 conversion
Post  johndickjr March 31st 2011, 8:40 pm
is there a kit to convert a demon carb to e85
johndickjr
demon e85 conversion Empty Re: demon e85 conversion
Post  4thHorseman April 1st 2011, 12:14 am
They had alcohol conversion kits for the demons. That should get you much closer for an e85 setup. BG is out of business so get one before they get scarce.
4thHorseman
4thHorseman
Post  GaryS April 1st 2011, 9:32 am
According to Quick Fuels, the boosters are slightly difference for gas, E85, and methanol. I am not familiar with Demon...if the inside is anodised aluminum, you might start by just increasing the jets. If not anodised, you will need to run the carb dry if it going to sit (weekend to weekend)...just like in the old days with methanol. My first attempt was not anodised. I drove it nearly everyday for most of the summer before I found snot growing in the fuel bowls. No damage to anything except the drivability. Just jelly floating around in the bowls.
GaryS
GaryS
Post  dfree383 April 1st 2011, 9:45 am
best option with BG going out of business..... Sell it and Get a Quick Fuel Holley Based E85 carb (or other brand if you have a preferance).......
Post  jc10000rpm April 2nd 2011, 8:33 am
why not get the e-85 conversion kit from qft and set it up. only mod to main body would be to increase size of boosters, and change the air bleeds
jc10000rpm
Post  dfree383 April 7th 2011, 8:35 am
jc10000rpm wrote:why not get the e-85 conversion kit from qft and set it up. only mod to main body would be to increase size of boosters, and change the air bleeds
The BG Dominator stuff has some unique parts.
Post  jc10000rpm April 10th 2011, 9:29 am
is this a mighty demon or a king demon ???
jc10000rpm
