Transmission Cooling
+8
D. Sea
342g
TheFrog
12 posters
Transmission Cooling Empty Transmission Cooling
Post  TheFrog March 31st 2011, 10:55 pm
Is it necessary to run transmission cooling lines from the transmission to the radiator in non-race/heavy duty applications?
Thanks,
Keith
TheFrog
Transmission Cooling Empty Re: Transmission Cooling
Post  Curt March 31st 2011, 11:01 pm
It is necessary to at least run them in a loop, but I personally think they should go thru a cooler. pig
Post  whatbumper March 31st 2011, 11:02 pm
they don't have to go to the radiator cooler but I would definitely run a cooler.
Post  TheFrog March 31st 2011, 11:39 pm
Thanks guys.
Is it better to run solid lines or flexible lines?
TheFrog
Post  DILLIGASDAVE April 1st 2011, 2:41 am
A long time ago I read where it was suggested for street/towing use in cold climates that you should keep the factory radiator trans cooler/warmer in the loop when adding an auxiliary trans cooler. But in warmer areas it was OK to bypass the radiator cooler/warmer & just use an aux cooler by it's self.
On drag cars I have seen guys with 'glides & TH400's not using any cooler & just looping a line. But it's usually on a car that doesn't see street use or doesn't get hot lapped at the track. The Rossler 2 speed TH400 stuff has plugs in both cooler line ports so you don't bother looping a line. Guess he does something inside the case/pump to redirect the flow.
For street use it's hard to beat using hard lines for most of the cooler plumbing with flex line used only at the connections vs using 100% flexible line.
Post  TheFrog April 1st 2011, 10:20 am
What is meant by, "running the lines in a loop"?
TheFrog
Post  342g April 1st 2011, 10:26 am
TheFrog wrote:What is meant by, "running the lines in a loop"?
Ju st get you a long piece of line hook one end to tranny, run it along frame rail, or something, and run it back to tranny, and hook other end up, just make a big loop with line.
342g
342g
Post  dfree383 April 1st 2011, 10:28 am
Run a cooler its necessary on the street and is benificial on race applications too. Cooler is better for transmission life.
Post  342g April 1st 2011, 10:31 am
dfree383 wrote:Run a cooler its necessary on the street and is benificial on race applications too. Cooler is better for transmission life.
....Definately !!!!!!!
342g
342g
Post  TheFrog April 1st 2011, 11:31 am
Thanks again guys!
The radiator I recently purchased already has a built in transmission cooler so I'll go ahead and hook into that. I was just wondering if I get by without hooking into it due to needing to run lines and stuff like that.
Keith
TheFrog
Post  dfree383 April 1st 2011, 11:47 am
You can use that one or a auxillary cooler too. Good idea to run both.
Post  D. Sea April 1st 2011, 12:06 pm
I run a stacked trans cooler with a thermostat controlled fan. Also running -8 teflon braided hose to and from the cooler. Overkill? Possibly, but the likelyhood of my transmission failing due to heat is slim to none.
D. Sea
D. Sea
Post  TheFrog April 1st 2011, 1:25 pm
Should an auxillary cooler and/or stacked transcooler be mounted up front with the radiator?
TheFrog
Post  richter69 April 1st 2011, 1:38 pm
pulled my big cooler and fan off, put one of them heat sink deals on and it works great in my application..........would not want to try it in a hot lap situation though.
Post  D. Sea April 4th 2011, 12:20 pm
TheFrog wrote:Should an auxillary cooler and/or stacked transcooler be mounted up front with the radiator?
If it has a fan, then you can mount it about anywhere.
D. Sea
D. Sea
Post  whitefield April 4th 2011, 4:04 pm
If it is a automatic of any kind size type shape form or fashion it needs a cooler! Evil or Very Mad
I have built a lot of transmissions out of pulling trucks and tractors over the years that a burned up due to pluging the lines or just looping it.
The transmission doesn't get its heat at wide open throttle third gear at say 7000rpm. The Torque converter greats heat and a lot of it at start because it is slipping. The higher the stall speed the more heat. Then once the heat is in it it is hard to get it out of it! Also that heat however much it is or how long it stays in it bakes the seals and causes the clutch and band material to deteriorate prematurely .
Put a cooler on it!
whitefield
whitefield
Post  jcoxracing April 4th 2011, 9:00 pm
If you do run a stacked design, just make sure you install it correctly! I have mine upside down!!!
Now that it is fixed all is good.
Justin
jcoxracing
jcoxracing
Post  richter69 April 4th 2011, 9:17 pm
my little heatsink deal worked pretty good, didnt mind the hot lapping last friday lol.
Post  wvmudder April 5th 2011, 2:03 am
Since this is about cooling a C6, what temps is recommended for a C6? Is there such a thing as too cold?
Dave S.
wvmudder
wvmudder
Post  res0rli9 April 5th 2011, 2:37 am
wvmudder wrote:Since this is about cooling a C6, what temps is recommended for a C6? Is there such a thing as too cold?
Dave S.
and what is to hot.
Post  D. Sea April 5th 2011, 11:55 am
My 180F Thermostat kicks the fan on...
D. Sea
D. Sea
