TNT 4-22-11
TNT 4-22-11 Empty TNT 4-22-11
Post  69F100 April 23rd 2011, 12:43 am
Not where I want it yet but better than last outing,ran 2 7.27s and 2 7.15s I need more this 850dp is not enough.The stall helped out good 60' time was down some I was getting alittle fast each time.
1st run
60'1.5658
330' 4.66
594' 6.80
1/8 7.2779
mph 94.17
2nd no changes except 1psi added to bring tires up to 9 psi
60' 1.4959
330' 4.56
594' 6.68
1/8 7.1587
mph 94.97
3rd timing change to 36*
60' 1.5769
330' 4.67
594' 6.79
1/8 7.2738
mph 94.51
4th run put time dack to 33*
60' 1.52
330' 4.57
594' 6.68
1/8 7.1541
mph 95.50
Here are 2 vids they are the last 2 runs
TNT 4-22-11 Th_albany4-22-11001-1
TNT 4-22-11 Th_albany4-22-11002
TNT 4-22-11 Empty Re: TNT 4-22-11
Post  cool40 April 23rd 2011, 12:47 am
how much better was your 60? Very Happy
Post  69F100 April 23rd 2011, 12:53 am
aroung .15 send me your addy
Post  cool40 April 23rd 2011, 12:54 am
not bad. Very Happy
Post  BBFmustang April 23rd 2011, 7:33 am
Cool sounds good Jim your getting close
BBFmustang
BBFmustang
Post  bruno April 23rd 2011, 9:12 am
very nice Jim , truck sounds awesome !!!
http://WWW.CKRME.COM
Post  BigDave65 April 23rd 2011, 9:21 am
I'm not familiar with your combo, but an 850 on an engine in the power range you are at, seems like it should be plenty of carb to me. We ran a dove headed 466 with a good roller cam, stock crank and rods, and 13:1 comp in a 2800+ lb car and went high 6-teens, low 6.20s with a stock 4779 750 carb. You may want to look at some other things first. This is what worked for us, just my $.02.
BigDave65
BigDave65
Post  69F100 April 23rd 2011, 11:39 am
Pulled the plugs this morning and it is lean I have the 850 fat as I can get it just not enough gas on top end.
Post  BigDave65 April 23rd 2011, 4:22 pm
Make sure you have enough fuel pump with no kind of restrictions with your fuel lines. Bigger jets won't help if there isn't enough fuel volume to keep up.
BigDave65
BigDave65
Post  richter69 April 23rd 2011, 4:25 pm
put the "other" carb on it.............. Wink Very Happy
Post  69F100 April 23rd 2011, 4:53 pm
the fuel to the bowls is not any problem in that area it has supplied enough to a 557 with 1250 took everything out of my buddys car and put in the truck for the gas system all the 1/2 lines have no sharp bends in them.It don't act as the carb runs out of gas but just like it at part troddle on top end.
Post  69F100 April 25th 2011, 5:29 pm
bump for a friend to see
Post  69F100 April 25th 2011, 6:18 pm
Dave I went out and check flow today it will fill a gallon oil jug to the gallon mark in 40 secs did it 2 times to make sure.This is with the line about 3 1/2' above the tank through the filter and regulator with 1 line unhooked from carb.
