stock flywheel hp limit
138
bb429power
tiger
stock flywheel hp limit Empty stock flywheel hp limit
Post  tiger April 29th 2011, 11:14 am
Will a stock flywheel take 750 hp? If not what flywheel do I need.
tiger
stock flywheel hp limit Empty Re: stock flywheel hp limit
Post  dfree383 April 29th 2011, 11:17 am
Get SFI billet one and scatter shield.
Plus get a sutiable clutch...
Its a safety Issue.
Post  tiger April 29th 2011, 11:40 am
I just realized I posted the wrong thing. Its a c6 so its a flexplate.
tiger
Post  dfree383 April 29th 2011, 11:42 am
Still a good idea to get a SFI approved one.
Post  bb429power April 29th 2011, 3:11 pm
I'm scared to put the stock one on mine even just for the break in. I have seen two BBF's blow up on the dyno (not in person) because they put the stock one on just temporarily. affraid
bb429power
bb429power
Post  whatbumper April 29th 2011, 4:16 pm
In a few weeks I will be able to start making pretty good deals on tranny stuff but not at this time.
Post  138 April 29th 2011, 5:33 pm
speaking of flex plates, whats the limit you would use this one for? I have a new one of these but never considered running it in a race engine...
http://www.summitracing.com/parts/HAY-12-060/
138
Post  quick 52 April 29th 2011, 7:54 pm
bb429power wrote:I'm scared to put the stock one on mine even just for the break in. I have seen two BBF's blow up on the dyno (not in person)
summit sale one for 79.99 its sfi for that money just get one
quick 52
Post  nuclearcobra April 30th 2011, 12:34 am
Call BFevans he has real good prices on scat sfi units.
nuclearcobra
nuclearcobra
Post  Wheelie58 April 30th 2011, 1:33 am
Whichever SFI wheel that you choose....pay particular attention to the ring gear attachment (welds) and make them part of your regular maintenance inspection. I have experienced failed ring gear welds, and know other racers who have recently had ring gears come apart. One caused a crash when the ring gear exploded, it cut the trans cooler lines at the frame rail and pumped ATF under the guys tires in high gear.
Dan-o has a customer that had one blow apart on a BBF/Glide deal last year too.
One of the manufacturers that I discussed this with noted that many failures of this nature happened on flexplates that had exceeded their 3-year SFI date and felt it was due to fatigue.
I am watching mine much closer, now.
Just things to consider...
Keith
www.KeithFulpMotorsports.com
Wheelie58
Wheelie58
Post  quick 52 April 30th 2011, 2:10 pm
Wheelie58 wrote:Whichever SFI wheel that you choose....pay particular attention to the ring gear attachment (welds) and make them part of your regular maintenance inspection. I have experienced failed ring gear welds, and know other racers who have recently had ring gears come apart. One caused a crash when the ring gear exploded, it cut the trans cooler lines at the frame rail and pumped ATF under the guys tires in high gear.
Keith
does this happen with lower hp cars say in the 500 range
quick 52
Post  Wheelie58 April 30th 2011, 10:30 pm
Keith
In my opinion...no.
More in the 850 to 1150 HP applications. At least that is where I have heard of the failures.
My earlier 700 (or so) HP deal never had any issues....even with stock flexplates before the SFI mandates.
Still a good idea to use a good quality part and inspect it regularly.
Keith
Wheelie58
Wheelie58
stock flywheel hp limit Empty What about in a jet boat
Post  CP598 May 3rd 2011, 9:34 am
Lem, or anyone else with experience in jet boats. Is there the same concern with the flexplate in this application, the reason I ask is there is no torque converter bolted to it.
Thanks.
CP598
CP598
