Engine Swap Flywheel question/ 400M Flywheel on a 460?
466cj
whitefield
Tore
I have a friend who is putting a 460 from a 76 Ford f150, into a 79 F350 with a standard shift. He needs a standard shift flywheel for it. Hes telling me one from a 390 should work is this possible?
Will the 400M flywheel work on the 460?
Thanks Tore
Thanks Tore
Last edited by Tore on August 9th 2012, 7:59 pm; edited 2 times in total (Reason for editing : more questions)
Tore- Posts : 865
Re: Engine Swap Flywheel question/ 400M Flywheel on a 460?
Tore wrote:I have a friend who is putting a 460 from a 76 Ford f150, into a 79 F350 with a standard shift. He needs a standard shift flywheel for it. Hes telling me one from a 390 should work is this possible?
Thanks Tore
Yes it will work ! we did this on 61 coons old bronco.
whitefield- Posts : 2244
Thanks Tore
You are right in the middle years when they changed from internally balanced to externally so be careful to get the right parts. They tend to shake really bad if you get it all backwards.
jasonf- BBF CONTRIBUTOR
Thanks guys Tore
Tore- Posts : 865
I will check w/Randy.He should have a few. I will call you.
Hes got the original flywheel from a 400m will that work on the 460?
Tore
Tore
Tore- Posts : 865
A 400 ford uses the SBF crankshaft bolt pattern which is not the same as 460 so the flywheel will not bolt up. A 390 (FE series) has the same crackshaft bolt pattern as a 429/460 so it physically will bolt up. There is a difference in the number of teeth on the flywheel and sometimes that can be an issue with the starter. Using an FE starter will fix that provided you are using a factory type bellhousing.
Another trap is the some 460's are internal balance and some are external. The 390 flywheel is internal. You need to make sure your 460 is internal balanced. From the factory 460's from 1979 model year and up were external balance, and the earlier ones were internal. An external balance engine will have a weight welded onto the flywheel and have "hatchet" shaped weight behind the balancer.
466cj- Posts : 391
Tore wrote:Hes got the original flywheel from a 400m will that work on the 460?
Tore
a 400 has an entirely different bolt pattern ... it won't fit.
Anybody got a 460 internal balanced flywheel?
Thanks for the info guys.
Tore
Tore
Tore- Posts : 865
You will have to check the pilot shaft brg for the 460, it will have to be shortened on some transmissions.
Thanks Blake.
Tore
Tore
Tore- Posts : 865
Tore wrote:Anybody got a 460 internal balanced flywheel?
Tore
You COULD buy a new one from Ford Racing Performance Parts...
There is not a 460 o ballance flywheel. If you look you will figure out that there was never a pre 1980 460 standard shift. Only was in teh 78/79 and they were only C6. You get a 460 flywheel and have it zero balanced its cheaper. Not to mention if you use a 460 flywheel youll need a 460 belhousing. doing the swap too......
barbatostan- Posts : 19
[quote="Tore"]I have a friend who is putting a 460 from a 76 Ford f150, into a 79 F350 with a standard shift. He needs a standard shift flywheel for it. Hes telling me one from a 390 should work is this possible?
Thanks Tore[/
the 351m and 400 wheels have a sbf bolt pattern,they will not work, a 390 wheel is net ballance,and will work on pre 78 460's without mod's
use the 351m or 400,429 or 460 starter with a 351m or 400 bell
Thanks Tore[/
BOSS 429- Posts : 2372
429 are all "0" balanced and came in cars prior to 1980. They are a direct swap to a 460. The FRPP piece is a good choice or one from a 390 can be made to work or can pay to have an 460 external balance converted...
466cj- Posts : 391
[quote="466cj"]429 are all "0" balanced and came in cars prior to 1980. They are a direct swap to a 460. The FRPP piece is a good choice or one from a 390 can be made to work or can pay to have an 460 external balance converted...[/quot
429s went away in 73,they were net ballance,460 became ext ballance in sept 78, 390s are net,but other fes are not even tho the flywheels will bolt right on a 429 or 460, and with as many changes things have gone thru after 40 years you have to be sure its not a 390 wheels reballanced for a 428,
and factory 429 wheels are a diff tooth count,and dia then the 390, thats why the 390 wheel with the 400 bell works
Yep, and I think we just about beat this flywheel thread to death
466cj- Posts : 391
466cj wrote:Yep, and I think we just about beat this flywheel thread to death
AMEN !
Guys thanks for all your input. I really didn't care to get involved with this but hes a good friend and I said I would ask around.
hes also as tight as the bark on the tree so we will see how this plays out.
Thanks again
Tore
Thanks again
Tore
Tore- Posts : 865
barbatostan wrote:There is not a 460 o balance flywheel.
The counter weight on a FRPP flywheel which I have for dyno usage is a BOLT-ON and can easily be removed.
Tore wrote:hes also as tight as the bark on the tree so we will see how this plays out.
Thanks again
Tore
Thats the pot calling the kettle Black
» 1979 Ford 400M engine
» I need source for 390 flywheel and clutch for 77 460 swap
» Flywheel to dyno engine
» engine swap
» 64 comet engine swap
» engine swap
