A460 block, same old questions!
D. Sea
lastminutedragracer
A460 block, same old questions! Empty A460 block, same old questions!
Post  lastminutedragracer May 3rd 2011, 3:28 pm
Well bought the block with big & quick ideas. But-----still have some questions.
1. how big or small to drill the oil restrection to the top end. Roller lifters and roller rockers.
2. had to clarance #2 &#4 web and cap. no end play with a scat crank. read here that some have had this problem.
3. what in the heck is the 1/4 in screw that fell out of the packing used for?
4. should the block be decked to say 10.305 insted of the 10.320?
5. can anyone recamend a good oil pan for an tube chaiss car?
6. more questions to come I'm sure.
Thanks for the info and help.
lastminutedragracer
A460 block, same old questions! Empty Re: A460 block, same old questions!
Post  D. Sea May 4th 2011, 12:18 pm
Correct me if I'm wrong guys, I don't have my notes in front of me.
Drill one of the restrictors to .062" and put it in the front or back but NOT both...
If you don't have pistons yet, get some so you don't have to deck the crap out of your new block. If you do have pistons then measure and deck accordingly in order to get the proper quench i.e .005" to .010"
Stef's pan or one of those custom deals from Lem
D. Sea
D. Sea
Post  D. Sea May 4th 2011, 12:22 pm
Here's some EXCELLENT information from when I built my engine with the A460 block... Enjoy Cool
https://www.429-460.com/t634-a460-block-534ci-engine-build-thread?highlight=A460+A429
Note how I had Adney Brown tweak the new crank and make it 4.310" instead of 4.300" in order to keep from decking the new block as much Idea
D. Sea
D. Sea
Post  lastminutedragracer May 4th 2011, 2:57 pm
Damon, read the thread. Great! Thanks for answering. Guess I have more work to do. Smile Thanks again.
lastminutedragracer
A460 block, same old questions! Empty paper work for a A460
Post  lastminutedragracer May 16th 2011, 3:14 pm
Well I have lost the paper that comes with the new blocks. can anyone tell me what was on it and where I might get another one? how about the oil plugs? Damon said the one gets drilled to .062 I just really don't want to screw this up. I've got the crank in and toqured to 105lbs. just don't know aboout those damn oil plugs. what goes where. and what ever else was on the paper. Thanks lost in Ohio.
lastminutedragracer
Post  res0rli9 May 16th 2011, 3:32 pm
lastminutedragracer wrote:Well I have lost the paper that comes with the new blocks. can anyone tell me what was on it and where I might get another one? how about the oil plugs? Damon said the one gets drilled to .062 I just really don't want to screw this up. I've got the crank in and toqured to 105lbs. just don't know aboout those damn oil plugs. what goes where. and what ever else was on the paper. Thanks lost in Ohio.
Lem can email you one.
Keith
Post  lastminutedragracer May 16th 2011, 3:35 pm
That would be Great! should I PM or just post my email?
lastminutedragracer
Post  dfree383 May 16th 2011, 4:31 pm
PM Lem Evans
Post  res0rli9 May 16th 2011, 4:51 pm
lastminutedragracer wrote:That would be Great! should I PM or just post my email?
EMAIL...Lem....HE DON'T LIKE PM's
Post  Lem Evans May 16th 2011, 5:28 pm
fordracingparts.com
FRPP tools
downloads
instruction sheets
Post  Yoeman May 16th 2011, 7:14 pm
http://www.fordracingparts.com/download/instructionsheets/FordInstShtM-6010-A460.pdf
Yoeman
Yoeman
Post  bbf-falcon May 16th 2011, 11:49 pm
Lem Evans wrote:fordracingparts.com
FRPP tools
downloads
instruction sheets
X2 Smile
Post  BOSS 429 May 17th 2011, 12:35 am
yes dont deck anything till you do your math for piston hight. the hole size depends on oil weight, dry sump,wet sump,etc, so get some parts in front of you before the wagon
Post  D. Sea May 17th 2011, 11:52 am
https://s45.photobucket.com/albums/f75/Phantasea466/A460%20Block/
A460 block, same old questions! A460InstructionSheetA
A460 block, same old questions! A460InstructionSheetB
D. Sea
D. Sea
Post  lastminutedragracer May 18th 2011, 3:20 pm
that's the paper. Thanks for the link to the downloads from other folks too. lots of info to work with now. Thanks again. Rick (Lastminutedragracer)!
lastminutedragracer
