early morning tech help! pilot bearing/bushing
early morning tech help!  pilot bearing/bushing Empty early morning tech help! pilot bearing/bushing
Post  frank13 May 7th 2011, 7:17 am
which on to use, bearing style or bushing?
also, is there a preferred one to get. the last one was a pilot bearing with roller bearing and it had to get forcibly installed (alot more force than i was comfortable with) I think i may have had the wrong one after the fact.
the crank is a stock oem ford internal balance crank. trans is a t56
i am replacing the flywheel on my car today finally and the bearing in there is in two pieces when i pulled the trans (the roller became dislodged from the outer bushing)
thanks for any quick responses
frank13
frank13
http://www.frankskinkracing.com
early morning tech help!  pilot bearing/bushing Empty Re: early morning tech help! pilot bearing/bushing
Post  LivermoreDave May 7th 2011, 12:19 pm
frank13 wrote:which on to use, bearing style or bushing?
Frank you probably know tons more about the pilot bearing issues than I. With that said, I do like the "upgrade" of the rollerized pilot bearing. Myself I would take that route. Although you mentioned the possibility of the wrong bearing application and the excessive effort required to install it, may have led to it's demise! I would think that a "rollerized pilot bearing" would fit the crankshaft snug since the idea of a bearing is for the rollers to rotate, not the "fit portion" (crankshaft contacted race or input shaft race). Also I think the input shaft would like the "rollerized bearing" much more than the bushing. Damn, I blabbing on and on again! My vote is for the BEARING.
Blabbing Dave.
LivermoreDave
Post  zbob May 7th 2011, 7:18 pm
i like bushings, lol. probably a hold over from my fractional horsepower electric motor days...bobn
zbob
Post  frank13 May 7th 2011, 8:00 pm
anyone have any input on which one to ask for car/truck wise (model, year, ect)
no one had one in stock today at either boys, autozone or advance, and napa closed at 2
but the old is out (3 pieces after drilling it out so it is of no use to check against!
frank13
frank13
Post  69F100 May 8th 2011, 2:07 am
i like the brass bushing the best if you can find one
Post  DanH May 9th 2011, 8:32 am
what crank/year ? large pilot older cranks ... same as 390 (all FE's) can find 429/460 in the book , ask for 390
DanH
Post  frank13 May 9th 2011, 8:16 pm
its an internal balance stock crank
frank13
frank13
