sparks were flyin !!!!
+19
D. Sea
bigblockfox468
605FOX
Barney
KY JELLY
f250mike
ThndrChkn
342g
56Tbird
23 posters
Page 1 of 2
Page 1 of 2 • 1, 2
...... had a great test and tune left everything the same except for the new scoop, jetted 2# up and strapped the front end down , on almost every pass i had to lift , and it seemed the engine was up about 3-400 rpm at idle on the passes i stayed in it it gained about 3 mph in the 1/8 amd about 5 mph in the 1/4 ....so i say the scoop is working well , and she is moving out the back door
the last pass it seemed to find a couple of extra ponies and did a second wheel stand past the 60' and came down and bent the wheel, broke the spindle and i need a new set of headers , and even my wife thought it was funny .... i will try and upload this video , but otherwise we are making progress with the power just have to get it down track ........
Re: sparks were flyin !!!!
you broke s**t and it was fun?sounds like it's maken some power.
can you say "Wheelie Bars" , all the fast cars run them! and they do have a purpose , tends to keep cars off the top of the guard rail!
Frank Merkl- Posts : 1524
I'm sure Julia will be all shyts and giggles when she sees the repair bill.... Maybe you should think about putting those sissy sticks on ,or at least staying in the throttle until you see God
56Tbird- BBF CONTRIBUTOR
[quote="56Tbird"]I'm sure Julia will be all shyts and giggles when she sees the repair bill.... Maybe you should think about putting those sissy sticks on ,or at least staying in the throttle until you see God [/quote
I haven't heard him say he saw Elvis yet, sounds like he his making a boat load of power.
342g- BBF CONTRIBUTOR
put the damn bars on it................
richter69 wrote:put the damn bars on it................
X2... That thing will be a missile once you get it tuned with the bars on it Nick. It'll save ya money down the road. Or is it down the track?
ThndrChkn- Posts : 2216
Lem Evans wrote:Engine idled up.........how far out are the idle mixture screws?
i havent touch them since you had your hands on it
Wow Nick
I hope you get a handle on that thing.
f250mike- Posts : 628
56Tbird wrote:I'm sure Julia will be all shyts and giggles when she sees the repair bill.... Maybe you should think about putting those sissy sticks on ,or at least staying in the throttle until you see God
did you hear her laughing in the video , when i brought it around to the pits she was pissed because Stephen told her i didnt want to put bars on it .... "i bought you those bracket thingys for cristmas and you havent used them " ....ok honey im putting them on .....jeesh
Frank Merkl wrote:can you say "Wheelie Bars" , all the fast cars run them! and they do have a purpose , tends to keep cars off the top of the guard rail!
bars are going on .......i want to keep the top side shiny
yes sir
Glad to hear nothing too serious happened there Nick. Fairly easy fix for what happened.
schmitty- Posts : 4538
2nd wheelie was front hitting it again while the front end was on the rebound.................you ever try to ride a wheelie out???? I'm not bustin your balls it just looks like a deal you could drive through.........or drag the brake pedal with your left foot a bit............
richter69 wrote:2nd wheelie was front hitting it again while the front end was on the rebound.................you ever try to ride a wheelie out???? I'm not bustin your balls it just looks like a deal you could drive through.........or drag the brake pedal with your left foot a bit............
i believe its easier said then done , i probably should have bailed the first time ...but oh well bars will be on by next weekend and we will give it a go again
bruno wrote:richter69 wrote:2nd wheelie was front hitting it again while the front end was on the rebound.................you ever try to ride a wheelie out???? I'm not bustin your balls it just looks like a deal you could drive through.........or drag the brake pedal with your left foot a bit............
Yeah like I said I'm not being a dick, it always looks less violent through a lens in the stands. Put the bars on and not have to worry about hurting stuff any more.
bruno wrote:Lem Evans wrote:Engine idled up.........how far out are the idle mixture screws?
I didn't say you had moved them just wonder where they are. An engine idling up can likely be lean......could be weather or a vacuum leak.
carbs is too hard.....too many screw thingys and air bleeds and such..........
richter69 wrote:bruno wrote:richter69 wrote:2nd wheelie was front hitting it again while the front end was on the rebound.................you ever try to ride a wheelie out???? I'm not bustin your balls it just looks like a deal you could drive through.........or drag the brake pedal with your left foot a bit............
i know your not , i just have to listen to the peanut gallery at the track if you know what i mean ...... ....... and the car doesnt feel violent it just feels like it doesnt want to stop rotating towards the sky ........ i guess just need to jet up and stop here from getting up on that tire , add some more wheel speed plus some sissy bars
Lem Evans wrote:bruno wrote:Lem Evans wrote:Engine idled up.........how far out are the idle mixture screws?
temps were around 74-76 deg and the humidity was around 40-44% and like i said i had jetted up the carb for the new scoop..... but as far as touching the carb sounds like to much stuff to f up ------- hopefully the bash will be soon and i can get some of your love on the carb
Looks like the car is makin good power Nick.
Glad you're seeing the light about wheelie bars Nick. Why waste some energy going up when you can use it to go forward.
Just another good, usable tool to adjust wheel speed. More adjustability is more gooder.
DILLIGASDAVE- Posts : 2262
what an idiot ..... i adjust the struts clockwise , thinking that is full tight ....well guess what ....not on the strange deals its counter clock wise for full tight .....im i right guys ? and i have about 4" of travel up front and that is way too much ......
Page 1 of 2 • 1, 2
Page 1 of 2
