Tubing bender
Dave Maxwell
Tubing bender Empty Tubing bender
Post  whatbumper May 12th 2011, 8:47 am
What do you guys use or recommend? Most of the stuff that we do is CM in only about 3 or 4 sizes so that is realy all I'm concerned with.
Tubing bender Empty Re: Tubing bender
Post  Dave Maxwell May 12th 2011, 9:08 am
I use a couple hossfeld number 2's one manual one hydraulic. I really like it. I have seen it in alot of chassis shops also.. So others like it also. There are alot of good brands out there. A hossfeld is a bit pricey. But you have alot of flexability
Dave Maxwell
Post  Fatback May 12th 2011, 9:09 am
Hossfeld Tubing bender is the only way to go !!
Fatback
Tubing bender Empty tubing bender
Post  85montess May 12th 2011, 9:27 am
I use a JD2 manual bender with the degree wheel and I have the 1 3/4", 1 5/8", 1 1/2", 1 1/4" shoes in the 90* version and I have the 1" shoes with the 3.5" radius in the 180* version. I bent a piece of 0.120 wall 1" tubing and then sliced it to make an insert in the 1" shoes and I can also bend 3/4" tubing. I used the bender to bend all of the tubing in the following SFI25.3 chassis.
Tubing bender IMG00003-20110412-1514
Tubing bender IMG00005-20110412-1516
Tubing bender IMG00006-20110412-1517
I have used the bender for almost 15 years without problems.
85montess
85montess
Post  whatbumper May 12th 2011, 9:36 am
I've looked into the hossfeld and some others including the JD2 one. I really like the quality of the JD2 tubing notcher that we have.
I was just looking on YB and none really stand out some hate one while others love it.
thanks guys
Post  Race Ready Fabrications May 12th 2011, 9:41 am
I've got the Pro Tools 105. I've used the hell out of it and never had an issue. I started out using it manually, that got old quick so I switched it over to air/hydraulic setup.
Post  DILLIGASDAVE May 12th 2011, 4:32 pm
I have an ancient early model manual JD2, had it about 20 years.
I think they were the first to discover the "correct" outer shoe design/layout using a slight amount of angle built into the shoe it's self (leading edge vs back edge) to aid the tubing better start the initial bend with less of an indentation from the inner die.
Post  Dave Maxwell May 13th 2011, 2:09 am
thought about a jd. Got my hossfelds at an auction. So I got them cheap compared to new. If new, I would have had to spend almost 18,000 for everything I have. Jd is definitely more compact.
Dave Maxwell
