JD Sqaured Model 32 Tubing Bender Question
canzus
747JetMech
Hey Guys
I purchased a new tubing bender and was wonder what experience you have had with these? I read the air over hydraulics is slow. The price on the electric pumps is pretty high. Has anyone found anything cheaper to drive these benders?
Also going to build a stand this weekend. I am concerned about the foot print size. Looks like it will have to be pretty large to keep things stable. I am making my portable and not mounting rigid to the floor.
Tom
Tom
747JetMech- Posts : 272
Re: JD Sqaured Model 32 Tubing Bender Question
Try here...
http://www.offroadfabnet.com/forums/
Mainly devoted to off road rigs, but tons of very good tech...
canzus- Posts : 28
Sorry no experience with the new model 32, mine is the old manual operated model #3. Even with hydraulic or electric power doing all the work for you, you still might think about anchoring the stand to the floor so it will be easier to put a long piece of tubing in the bender without fear it might fall over. It's also easier to figure/set up compound angle bends if the bender is mounted rigid & not moving around.
I put a set of flush threaded anchors in the shop floor in two spots so I have a choice of where to put the bender/stand in the shop.
DILLIGASDAVE- Posts : 2262
Dilligas
A flush mount? Hmmmm Never saw one that goes into concrete. Where do I get one?
I run the 32 and love it i have done 1 5/8 .120 wall with one hand the anti kick back is cool and keeps the stroke down.
Northwest outlaw- Posts : 962
DILLIGASDAVE wrote:Sorry no experience with the new model 32, mine is the old manual operated model #3. Even with hydraulic or electric power doing all the work for you, you still might think about anchoring the stand to the floor so it will be easier to put a long piece of tubing in the bender without fear it might fall over. It's also easier to figure/set up compound angle bends if the bender is mounted rigid & not moving around.
Like Dave I have an older model manual operated that is floor mounted. Mine may have an 8"x8"x 1/4" plate on the bottom, not real big. A friend of mine who is a rock crawler fabricator has a rolling table that his bender is mounted to. His is air over hydraulic and seems to work fine on the rolling table.
TravisRice- BBF CONTRIBUTOR
I forget what these flush in-floor threaded anchor "slugs" are called but they are two piece expanding assemblies that lock themselves into drilled holes in the floor.
The inner steel sleeve is kinda tapered on the outside & threaded on the inside. The outer sleeve is made of soft lead. The inner tapered sleeve pulls up through the lead outer sleeve in the floor when you install them locking them into the hole in the floor.
This gives you a threaded anchor hole down in the floor, instead of threaded anchor bolts sticking up-out of the floor to trip over.
I will take a pic of an anchor if I can find one of the extras I bought long ago.
747JetMech wrote:A flush mount? Hmmmm Never saw one that goes into concrete. Where do I get one?
http://www.mcmaster.com
Search for screw anchors...
Scroll down this page...
http://www.mcmaster.com/#catalog/115/3263/=4i1253
Simple!
canzus- Posts : 28
they are call a few thing rock bolts ,anchors ,red heads hope that helps
Drop in anchors. Your local Fastenal carries them. Mine are 1/2" threaded inside, I think they are a 3/4 or 5/8 hole for the concrete.
Travis
Travis
no experience with that one.
I have 2 hossfeld number 2 benders. One is hydraulic, mounted on a rolling cart and the other is floor mounted with the concrete anchors.
If i had the room, i would mount the hydraulic one to the floor as well.
Its easier to swing that long tubing around outside at this time.
Dave Maxwell- Posts : 576
Thanks Travis
Thanks Travis. There is a fastenal just down the road.
Tom
Tom
Could only find one anchor and of course it's missing it's outer lead sleeve (figures) but you get the idea.
this from Fastenal is very similar to what I have.
http://www.fastenal.com/web/products/detail.ex?sku=51009&ucst=t
Pic of the bender/stand. I use a few washers as leveling shims (where needed) under the mounting feet/bolts to adjust the level on all 4 corners.
DILLIGASDAVE wrote:Could only find one anchor and of course it's missing it's outer lead sleeve (figures) but you get the idea.
Dave, I beleive the 2 piece anchor that you are referencing takes a set tool that threads into the anchor then you smack it with an hammer and it pulls the bottom up through the top.
I used a Hilti I peice anchor that has a threaded inside and a nylon plug inside that you drive into the floor and the bolt pushes the plug down hence tightening the ancor in the concrete.
Travis
TravisRice wrote:Dave, I beleive the 2 piece anchor that you are referencing takes a set tool that threads into the anchor
If you don't drill the hole too deep (or too big a diameter) in the floor, an installation tool usually isn't needed for these lead sleeve anchors.
Usually just smacking what little of the anchor that might sit above the floor with a hammer first is usually enough to get things going & allow you to set the anchor the rest of the way with just a large/thick flat washer & a short 1/2-13 bolt. Crank on the 1/2 bolt with a socket/ratchet untill the inner threaded sleeve pulls up close to the washer & it's done.
» JD Model 32 tubing bender
» Tubing bender
» Tubing notcher
» Bender
» What do you guys thank of this bender???
» Tubing bender
» Tubing notcher
» Bender
