convert gas carb to alcohol
+6
PaulS
342g
johndickjr
10 posters
convert gas carb to alcohol  Empty convert gas carb to alcohol
Post  johndickjr May 23rd 2011, 7:46 am
i am thinking about trying alcohol on my new motor , i found a web site that explains how to drill the block and main body passages out for alcohol , has anyone ever done this
johndickjr
convert gas carb to alcohol  Empty Re: convert gas carb to alcohol
Post  David Cole May 23rd 2011, 9:10 am
I've seen a couple of guy try and it didn't work too well for a first timer. If I were going convert a carb I would send it to one of the big names and pay them to do it. Send it to George Rupert, APD or Bo Laws. All three make great alky carbs and can convert yours.
Post  richter69 May 23rd 2011, 10:22 am
^^^ X2
Post  johndickjr May 23rd 2011, 10:28 am
ok..thanks..will prob just stay on gas
johndickjr
Post  342g May 23rd 2011, 2:06 pm
I'll sell you a good A.P.D., for $600.00 plus ride, 1050 dommy
342g
342g
Post  PaulS May 23rd 2011, 11:36 pm
johndickjr wrote:ok..thanks..will prob just stay on gas
Can you share the site you found? I am interested in retuning my carb for alcohol and would like to try it myself.
Paul
PaulS
Post  johndickjr June 1st 2011, 9:31 am
Paul
http://www.hardtail.com/techtips/alcoholconversion.html
johndickjr
Post  dfree383 June 1st 2011, 9:57 am
Quick Fuel offers kits to convert to Alky and Ethanol.
Post  johndickjr June 1st 2011, 11:39 am
dfree383 wrote:Quick Fuel offers kits to convert to Alky and Ethanol.
about 300-400$$
johndickjr
Post  dfree383 June 1st 2011, 11:44 am
about 300-400$$
Yep.... That's what they cost.... Doing something Right and not destroying the carb in the process so it can be converted back of you wish isn't free.
Maybe you'd be better served buying a used Alky carb and trying it, if you like it sell you Gas one, if not sell the alky one???? Nothing Lost in the process.
Post  Tommyj466 June 1st 2011, 1:56 pm
I used that quick fuel kit last year. It is a good kit with good instructions. The bosters supplied in the kit have kinda large skirts that probably hinder flow a bit, but carb worked pretty well. Carb can be converted back to gas as well with a few small parts.
TJ
Tommyj466
Tommyj466
Post  fc2444 June 1st 2011, 2:37 pm
Just send it to George Rupert and be done with it.
fc2444
http://amr-coatins.com
Post  richter69 June 1st 2011, 5:03 pm
I've had a few Rupert's, never again lol.
Post  the Coug June 1st 2011, 9:38 pm
richter69 wrote:I've had a few Rupert's, never again lol.
me too and a couple bolaws
last couple I had were Biggs worked great
Post  PaulS June 2nd 2011, 1:23 am
I have seen dyno results with some Quick Fuel kits installed and they seem to go over-rich in the mid-range. Almost like they are set up for Methanol instead of Ethanol.
Paul
PaulS
Post  PaulS June 2nd 2011, 1:24 am
Paul
Thanks for the link. It was one I already had but I never turn down the opportunity for more information.
Paul
PaulS
Post  dfree383 June 2nd 2011, 7:11 am
PaulS wrote:I have seen dyno results with some Quick Fuel kits installed and they seem to go over-rich in the mid-range. Almost like they are set up for Methanol instead of Ethanol.
Paul
Most things require some tuning, reguardless of who they are from.
The Kits are built for general application, not your specific motor.
Post  LivermoreDave June 2nd 2011, 8:15 am
Some time ago I did a nice Chrysler engine for a "Pro Street" car of sorts. A lot of time went into building that engine with attention to many details. In the end I delivered a nice "low compression" drag race style engine that would perform on the street with street tires. I was proud of the finished product and so the customer. The one mistake I made, was not "running in" the engine before it left my shop. I simply ask the customer when you are ready to fire it call me and I would like to assist in the initial starting of the engine. NO CALLS! Until a few weeks when a complaint of spark plug fouling was discussed. I asked all the questions while not trying to insult my customer! Finally after a week of phone calls I visited the customer and we went about looking for problems with the ignition parts. I found no issues with the ignition system, yes the plugs were fouled for the most part. I removed the valve covers. A few seconds later the butterfly's took over my stomach! I began to smell gas fumes within the oil base. Then I spotted a "large gap" between a rocker arm and the valve tip! Well most of you know the "Rest of the Story"!
My point being, if you have a nice engine, new or old, don't fuck it up with an un-certain fuel system!
Dave.
LivermoreDave
