Boat engine carb convert to drag engine
Boat engine carb convert to drag engine Empty Boat engine carb convert to drag engine
Post  pigs521bbf May 10th 2019, 10:35 pm
I have picked up a 1150 cfm Holley dominator that was on boat engine. What do I need to do to make it work on my drag racing engine?
pigs521bbf
Boat engine carb convert to drag engine Empty Re: Boat engine carb convert to drag engine
Post  rmcomprandy May 10th 2019, 11:49 pm
pigs521bbf wrote:I have picked up a 1150 cfm Holley dominator that was on boat engine. What do I need to do to make it work on my drag racing engine?
IF it is an actual Marine carburetor then change the vent tubes.
Post  pigs521bbf May 11th 2019, 4:32 pm
Is that it? Nothing to change internally ?
pigs521bbf
Post  dfree383 May 11th 2019, 7:58 pm
It will just need tuned to your combo
Post  pigs521bbf May 15th 2019, 7:13 pm
Looking to make the carb is 1150, but there is no model number or date number.
On the base says 12R-11259-3B. I just want to know the “true” cfm
pigs521bbf
Post  rmcomprandy May 15th 2019, 11:55 pm
pigs521bbf wrote:Looking to make the carb is 1150, but there is no model number or date number.
With a 1050 the Venturi are 1.690" and with an 1150 the Venturi are 1.812" ... the throttle bores are the same size.
