Hydralic roller compared to solid roller
About how much hp can hydralic rollers make? How much spring pressure? Can the two roll on the same cam? About how high in rpm can hydralic rollers safly reach?
tconnection- Posts : 866
Re: Hydralic roller compared to solid roller
In a big block Ford the power levels which can be attained is not even close to the same.
A hydraulic lifter roller set-up won't make as much power as a good solid flat tappet set-up.
A hydraulic roller camshaft with SOLID roller lifters is a good way to go if your looking to make a bunch of torque.
Thanks for the info.
» What to do solid roller/hydro roller
» Using Hydraulic roller lifters on the Comp XR292 R-10 Xtreme Energy Solid Roller cam?
» hydraulic roller cam with solid roller lifters
» JT557 HERE NEED SOLID ROLLER LIFTERS FOR ROLLER CAM
» Looking to trade a comp solid roller cam I have for a Hyd roller
