750 double pump, manual secondaries, adjustable jets
ok , so i picked up a 750 holley, with percy adjustable jets, carb is rebuild, clean and in great shape.
so i need to pick a "jet" size to start with. what is a good starting point jet wise for a mld 460 with wieand stealth intake, 600 lift cam, manual trans.
also, any recommendations on needle setting, and a close setting for the floats, before i try to fire this up
Re: 750 double pump, manual secondaries, adjustable jets
72 to 76 primaries....78 secondaries
zbob- Posts : 271
bob. the higher the number jet the leaner or richer?
the higher the number the richer
reeseracing23- Posts : 70
» Single or Double Adjustable?
» Jegs double adjustable coil overs
» Pop out 2 freeze plugs
» Have to pump manual brakes
» Mustang (Foxbody) double adjustable upper and lower control arm package
