Main cap bolt question... installing M-6675-A460 oil pan
Ok, I'm swapping a Fox body oil pan on my 460 and I'm not sure how to change the main cap bolt.
I'm a complete noob, so don't assume I know anything... this will need explained real well...
Do I just remove the old bolt, install the new bolt?
How much torque for the new bolt? Does it have to be the exact same torque as the old bolt?
Do I need to oil the bolt? What type of oil?
7.5- Posts : 15
Re: Main cap bolt question... installing M-6675-A460 oil pan
Remove the old on the install the new one to the same torque spec with 30wt motor oil.
Do I use a torque wrench to determine the current torque spec? Or just torque to what the book says?
7.5- Posts : 15
Use the Book spec.
7.5- Posts : 15
» question on compression ...using pump gas (a460...using fms a460 heads)
» milodon 4 bolt main caps question.
» 4 bolt main conversion? Or 2 bolt main stud girdle?
» Installing main cap dowels to help control maincap walk
» Cometic MLS head gaskets
