cometic gaskets
+7
BigDave65
KY JELLY
powerstrokeace
cooter
11 posters
cometic gaskets Empty cometic gaskets
Post  cooter June 6th 2011, 11:59 pm
what do you do when installing cometic gaskets, install them out of the package or coat them with something? cometic says not to coat them with anything but many say you must coat them. I use PERMATEX HIGH TACK but am courious what you do.
cooter
cometic gaskets Empty Re: cometic gaskets
Post  powerstrokeace June 7th 2011, 12:13 am
Cooter. If its a multi layered gasket I think there has to be a very fine finish to both the block and the heads for this to work. If not they will leak. I assume your talking head gaskets
Ace
powerstrokeace
powerstrokeace
Post  cooter June 7th 2011, 12:38 am
yes i am talking multi layered head gaskets.
cooter
Post  powerstrokeace June 7th 2011, 12:56 am
Better call Lem or Charlie on this.
Ace
powerstrokeace
powerstrokeace
Post  Lem Evans June 7th 2011, 9:15 am
If the deck is nice and slick I don't use anything........some use the spray copper coat.
Post  bruno June 7th 2011, 9:25 am
i believe they look for a 50RA finish or better , any ruffer will comprimise the design of the gasket
http://WWW.CKRME.COM
Post  cooter June 7th 2011, 9:58 am
cometic says to install dry with a 50 ra but it seems that everyone else says you take a big chance of leaking if you install dry which is why i figured i would ask the people that use them. I sure like them but want to make sure i am not tearing motors apart to fix leaking gaskets. thanx for the help
cooter
Post  Lem Evans June 7th 2011, 10:32 am
what few 'leaks' I've seen have been but slight drips.........a little stop leak is all it takes to resolve it. Sounds like people have got you spooked for no good reason.
Post  KY JELLY June 7th 2011, 10:41 am
I am probably one of the few that have had a slight leak and it was tune related more than likely. I just reused one , cleaned it up and sprayed with copper coat and am having no problems , that's with a 10 bolt head. I don't see any problems using the copper coat if a guy wants to.
KY JELLY
KY JELLY
Post  BigDave65 June 7th 2011, 3:08 pm
When I installed mine new I put them on dry. When I reused them I just cleaned them up and sprayed coppercoat on them. No issues that I have seen.
BigDave65
BigDave65
Post  whatbumper June 7th 2011, 10:48 pm
we put them on dry and have no leaks at the gasket. now these sb tfs heads keep cracking like crazy so we get some water in the chamber but I'm not starting that again on here.
Post  Wheelie58 June 9th 2011, 7:16 am
I like using Copper Coat, since it is easy to find and seems to work well. I started out using spray Hylomar, but that is harder to find. I think you can buy illegal dope easier.
No drips...no leaks...10 bolt.
Keith
Wheelie58
Wheelie58
Post  dfree383 June 9th 2011, 7:34 am
As long as the block and head finish is correct I typicaly install them dry the first time and the copper coat them for the next 2 installations, then get new ones. First time I used them I did have leaks on the exterior by the rivets and pulled my hair out about it, used some engine rebuilder stop leak pellets and everything was fine, haven't had an issue with them since then. That was Iron heads on a iron block too and that could have had something to do with it?
Post  rmcomprandy June 9th 2011, 9:43 am
Surface finish of the adjoining metal is most important to sealing.
IF the finish is correct then you don't need anything however, most resurfacers leave a rougher finish than desired so, very SLIGHT copper coat or high tack may be needed.
The OE manufacturers combined for a large study on the multi-layered steel head gasket sealing and found that an Ra finish of 16 is the roughest it should be ... take that for what you think it's worth. They build millions of engines per year.
Post  A70maverick June 9th 2011, 4:30 pm
I used mine the first time right out of the pkg. Then when I put them back in this spring I used em dry again. No leaks either way.
A70maverick
